My 2010 Passat CC 2.0T FWD sometimes does not shift out of P. Transmission module shows code:
17130 - Pressure Control Solenoid 1 - P0746 - 012 - Implausible Signal or Stuck Off - Intermittent
a) what DSG model/size/ID is installed in my car?
b) on 'tradional' transmission with similar code, the 'valve body' can be replaced with a refurbished one. Not sure if DSG trannies have such a thing?
c) Suggestions to trouble shoot the issue. Buy refurbished "valvebody' (part number, how to source, what is it called)? Swap used transmission in?
Any suggestions how to proceed from here are appreciated.
There is a valve/solenoid body on the side. I think it can be removed from the wheel well.
No, the Mechatronic sits on the transmission, under the oil pan. The valvebody/mechatronic includes all the solenoids/valves.
It looks like on the side (I come from longitudinal engine, and there it under the transmission oil pan).
2010 CC 2.0T DSG. Want to change the transmission (or just the valve body/mechatronic). I have LTK transmission code (and error code pressure control solenoid 1 code 17130 P0746). Are there other transmission codes that I can use, for example LQY?
