1 - 2 of 2 Posts
I've been working for the last few weeks on updating my GW and CCM so I can retrofit the Discover Media Headunit among other things. nycdub2 has provided me with great levels of help to get everything properly completed to this point. Everything is working as before when I had the original GW and CCM to include ELV steering lock fault. However, the one thing I can't seem to figure out is my power hatch. I hit the door button, the remote or the button at the hatch and it wont open. It makes the noise as its starting to open but wont actually open up. I swapped back in the old 3C0 CCM and it works with no issues from all three locations. I put the 3AA CCM back on and everything works except again the hatch wont open. I even tried opening it with the old CCM and leaving it open. Swap to new CCM and hit the button on the hatch to close it and it closes no problem but won't open again. It even makes a "thunk" sound when is attempting to open, like something is preventing it from moving. I was thinking some sort of trailer installed was enabled but in VCDS GW and CCM measuring blocks indicates that there is no trailer attached. Just looking for any assistance. I have attached my auto scan, thanks again for all your help.
Monday,01,January,2018,11:49:29:00176
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.8.1.0 (x64) HEX-V2 CB: 0.4401.4
Data version: 20171130 DS276.6
www.Ross-Tech.com
VIN: WVWXM7ANXAE165578 License Plate:
Mileage: 156110km-97002mi Repair Order:
Chassis Type: AN-VW46 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 52 53 56 5D 62
6D 72 77
VIN: WVWXM7ANXAE165578 Mileage: 156110km-97002miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
5D-Operations -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CBF) Labels:. 06J-907-115-CBF.clb
Part No SW: 06J 906 021 C HW: 06J 906 021
Component: MED17.1 6993
Revision: E3H23--- Serial number: VWZCZ000000000
Coding: 040401081C070160
Shop #: WSC 05314 000 00000
VCID: 2514FBE2B9E10D2F097-8070
1 Fault Found:
005488 - Engine Start Blocked by Immobilizer
P1570 - 000 - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 155935 km
Time Indication: 0
Date: 2012.05.22
Time: 00:32:07
Freeze Frame:
RPM: 1337 /min
Load: 11.0 %
Speed: 0.0 km/h
Temperature: 68.0°C
Temperature: 17.0°C
Absolute Pres.: 1010.0 mbar
Readiness: 0000 0000
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 053 A HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2106
Revision: 51112 Serial number: 00001005040033
Coding: 0000020
Shop #: WSC 05311 000 00000
VCID: 1370B53A6775839FF73-8046
No fault code found.
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 AF HW: 3C0 614 109 AF
Component: J104 C4 440 V2 0015
Revision: --025--- Serial number: 00000705652870
Coding: 0000380
VCID: 629EA0FEE84FBA172C5-8036
Address 08: Auto HVAC (J301) Labels:| 3C8-907-336.clb
Part No SW: 3C8 907 336 AJ HW: 3C8 907 336 AJ
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000081002
Shop #: WSC 05311 115 12345
ASAM Dataset: EV_Climatic A01005
ROD: EV_ClimaBasis_VW36.rod
VCID: 75B4EBA245413DAF797-8020
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Component: Bordnetz-SG H54 2602
Revision: 00H54000 Serial number: 00000003866346
Coding: E58C8B3140041A00CF0000000F0000003209514264000100000000000000
Shop #: WSC 05124 123 12345
VCID: 333015BA0735639F973-8066
Subsystem 1 - Part No: 3C1 955 419 B Labels: 1KX-955-119.CLB
Component: Wischer 270410 006 0208
Coding: 00046997
Shop #: WSC 05124
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 020914 054 0403
Coding: 00471080
Shop #: WSC 05124
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 Q HW: 5N0 959 655 Q
Component: J234__00C VW10 HI 1918
Revision: 22014000 Serial number: 003JZP99GZVA
Coding: 0012355
VCID: 4BC06D5A7FC51B5FFF3-801E
Subsystem 1 - Part No: 3C0 959 339 D
Component: BF-Gewichtsens. 001 0002
Subsystem 2 - Serial number: 00000000006WRU
Subsystem 3 - Serial number: 0031.03.100000100000650048ÿ†63
Subsystem 4 - Serial number: 650048ÿ†6332MTS623750930 ÿ†63
Subsystem 5 - Serial number: 50930 ÿ†6342MTS656930920 ÿ†63
Subsystem 6 - Serial number: 30920 ÿ†6351HTS6S5AMA6KR ÿ†63
Subsystem 7 - Serial number: MA6KR ÿ†6361HTS6UTIKA6KR ÿ†63
Subsystem 8 - Serial number: KA6KR ÿ†63727TS6CV11A6KJ ÿ†63
Subsystem 9 - Serial number: 1A6KJ ÿ†63827TS6CUD0A6KJ ÿ
Subsystem 10 - Serial number: 0A6KJ ÿ
Address 16: Steering wheel (J527) Labels:| 3C0-953-569.clb
Part No SW: 3C9 953 501 BG HW: 5K0 953 569 T
Component: LENKS.MODUL 009 0135
Revision: FF010036 Serial number: 20100504300749
Coding: 198A270002
Shop #: WSC 05311 115 00000
ASAM Dataset: EV_VW360SteerWheelUDS A03004
ROD: EV_VW360SteerWheelUDS.rod
VCID: 6FB8D9CA271D077FB3B-803A
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D Labels: 3C8-959-537.CLB
Component: E221__MFL-TK6 H06 0022
Coding: E20000
Address 17: Instruments (J285) Labels:| 3C8-920-xxx-17.clb
Part No SW: 3C0 920 972 L HW: 3C0 920 972 L
Component: KOMBI H03 0305
Serial number: 00000000000000
Coding: 261F00
Shop #: WSC 05314 115 12345
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
ROD: EV_Kombi_UDS_VDD_RM09_A04_VW32.rod
VCID: 2F3819CAE79D477FF3B-807A
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 BL HW: 7N0 907 530 AN
Component: J533 Gateway H56 1682
Revision: H56 Serial number: 090717F1002437
Coding: 462006
Shop #: WSC 12345 123 12345
VCID: 7BA0FD9A63E56BDF0F3-802E
1 Fault Found:
02749 - Control Module / Control Head for Telephone (J738)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 3
Mileage: 156116 km
Time Indication: 0
Date: 2012.05.24
Time: 11:49:06
Address 25: Immobilizer Labels: 3C0-959-433-25.clb
Part No SW: 3AA 959 433 A HW: 3AA 959 433 A
Component: IMMO 052 0399
Revision: 00052000 Serial number: VWZCZ000000000
Shop #: WSC 131071 1023 2097151
VCID: 372821AA134D8FBFABB-8062
Subsystem 1 - Part No: 3C0 905 861 H
Component: ELV 028 0380
3C0905861H ELV 028 0380
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
Component: SG EXT.PLAYER H13 0090
Revision: A1001003 Serial number: 7668032109
Coding: 010000
VCID: 2616FCEEC8E7063700D-8072
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 3C0 035 684 J HW: 3C0 035 684 G
Component: RNS-MID H02 4366
Revision: AB001001 Serial number: VWZ6Z7N7007014
Coding: 0E000402040000900011
VCID: 2A0E08DEDCFF2257245-807E
Subsystem 1 - Part No: 7L6 919 859
Component: NAR V11 8407
2 Faults Found:
00857 - CD Changer Unit (R41)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 3
Mileage: 156112 km
Time Indication: 0
01550 - Signal for Reverse Gear
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 3
Mileage: 156116 km
Time Indication: 0
Date: 2012.05.24
Time: 11:49:08
Address 42: Door Elect, Driver (J386) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 3C0 959 701 HW: 3C0 959 793
Component: TUER-SG FT 002 0305
Revision: 13101005 Serial number: 0000837273
Coding: 0014B5
ASAM Dataset: EV_DCU42BroseDriveSide A03004
ROD: EV_DCU42BroseDriveSide.rod
VCID: 6594BBE2F5E1CD2FC97-8030
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 703 A HW: 3C0 959 795 A Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 004 0401
Serial number: 00000001444389
Coding: 000490
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 K HW: 5N1 909 148 G
Component: J500__APA-BS KL.148 0703
Revision: 1AH03726 Serial number: 00101230034001
Coding: 0000258
VCID: 3A2E389E205F92D7545-806E
Address 46: Central Conv. Labels:. 3C0-959-433-46.clb
Component: KSG PQ47 ELV 052 0631
Coding: 1B910F8001862E521204141FF08A0F0E085801
Shop #: WSC 05311 123 12345
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 52: Door Elect, Pass. (J387) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 3C0 959 702 HW: 3C0 959 792
Component: TUER-SG BT 002 0305
Revision: 15101005 Serial number: 0000830572
Coding: 0014B4
ASAM Dataset: EV_DCU52BrosePasseSide A03004
ROD: EV_DCU52BrosePasseSide.rod
VCID: 6696BCEE08E7C637C0D-8032
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 704 A HW: 3C0 959 794 A Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0401
Serial number: 00000001428205
Coding: 000490
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 3C8 907 801 E HW: 3C8 907 801 E
Component: J540 EPB3 VW-15417 0007
Revision: 010 Serial number: 00000000271515
Coding: 0000057
VCID: 2C020EC6DA0B3C67D69-8078
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 3
Mileage: 156112 km
Time Indication: 0
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 3
Mileage: 156116 km
Time Indication: 0
Date: 2012.05.24
Time: 11:49:08
Address 5D: Operations
Cannot be reached
Address 6D: Trunk Elect. Labels: None
Part No SW: 3C9 827 383 G HW: 3C9 827 383 J
Component: J605 HECKDECKEL 0730
Revision: 00H27001
VCID: 35342BA209417DAFB97-8060
Subsystem 1 - Part No: 3C9 827 384 G
Component: J756 HECKDECKEL 0730
Subsystem 2 - Serial number: 1000H27001001B0163ÿ
Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
Part No SW: 7P6 035 730 K HW: 7P6 035 730 K
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007664263600
Coding: 0A11040000010110
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 3A2E389E2CDF92D7545-806E
End----------(Elapsed Time: 01:30, VBatt start/end: 14.2V/14.2V)-----------
Discussion Starter #2
Figured it out, it was definitely a wrong coding. A member in Ross Tech had already gone through same issue and figured it out, thanks.
1 - 2 of 2 Posts
