1 - 3 of 3 Posts
I searched before posting and did not find and answer.
I just finished swapping out my blower resistor which I found the cure for here. Thanks..
I noticed my switch that controls where the air is diverted to is not working.
Is this common for the switch to fail or could it be a fuse?
Last question. 2007 B6 Passat Value Edition Wagon 2WD 2T - I'm confused about what trans I have in this. I need to red up on servicing it. Thanks in advance
I assume you've a Climatic three-knob control system there? The air direction is by a Bowden cable that comes away from the control knob when control panel is disturbed. So that has to be replaced, if indeed it's adrift, in the matching position of where the controls were when it came apart. Fiddly job but do-able.
Your trans code is on the sticker on the inside front page of your service book. That same sticker is on your spare wheel well.
For Tiptronic your age would be 09G, less likely is DSG (09M) Otherwise you've got manual stick shift? Both auto boxes need ATF and filter change every 40k miles
1 - 3 of 3 Posts
