If those lights are on, there must be fault codes.
Do a full scan with VCDS or other good VAG scanner, and post the codes.
Can you post a picture of what you are looking at/comparing to? Because, I'm pretty sure all B5.5 ABS modules look the same on the outside.There also isnt a 2 wire plug or a 53 fuse
That is not a 2004 Passat Module.I noticed the pictures posted is not the right abs module, mine is completely black and no step its flat. View attachment 108581
