I am in dire need of some real insight and suggestions regarding the sound sytem in the Passat. I bough some new speakers an amp and a basslink. Got the speakers in without problem. Here's where the problems started. Sorry for the length.
I took the car to Circuit City for the basslink and AMP install and they broke a frigging lock on the headunit trying to get it out. So I took it to my dealer to have them pop it out. They put the tools in and tried for about 5 minutes and then told me to go screw myself that it isn't supposed to be removed and they wouldn't remedy the problem. (Devon Hill Motors --- Stay away from these clowns). So I took it over to another dealership (YBH) and they pulled the car into the garage and worked on it for 45 minutes and couldn't get it out. They said to make an appointment and they would "bust it out" and replace it with a new one. Just a little background for my real questions.
So I have the new speakers in (Infinity Reference 6002i's) and the setup sounds really good. At this point I am debating on whether I really need to install a new amp (Alpine MRP-F240). Do you all think this is necessary? For those of you who have installed an aftermarket amp is the quality difference really going to be noticeable?
On to the basslink. I am definitely going to install this as the current setup doesn't really have enough bass for my liking. So what is the best way to go about doing this? If I don't do the 4 channel amp, I was just going to tap into the rear speakers and be done with it (obviously gonna run power from the battery up front). It seems that the basslink auto-senses current when using speaker level input so there will be no need for wiring the remote turn on.
For those of you who have installed amp's. Did you use a high-low converter and run RCA or did you just use speaker level input? Also where did you grab the remote turn on feed for the amp. I was thinking of doing this from the fuse box. What have others used? Is this the best way to do it?
