Got a 2004 1.8t wagon with 120k on it
Seems that recently the car is vibrating more and more at a stop, most noticeable at a red light. Car in drive and foot on brake. Dont notice it when driving. Any thoughts?
Timing belt done about 20k miles ago
OK. In my experience, most 4-cyl automatic transmission cars do this they as they get older - the Passat is known for it; it's a common problem. Why is a little controversial. The most common diagnosis is bad motor mounts, followed by cheap axles, which makes little sense to me.
Now, IMHO, what we have is a complex situation, at least on my car it was. If the engine isn't running up to snuff, it tends to bog down and vibrate, as the drag of the transmission tries to stall it. So, anything you do for better running and less drag helps.
When I got my 2000, it had almost 180,000 miles and vibrated badly when stopped in drive. As I went through the car, changing air filter, spark plugs, cleaning the throttle body, cleaning the PCV system - each made a small improvement. Changing the ATF and filter made the biggest difference. Cumulatively, it now (at 236,000 miles) idles almost as smoothly as my 2004 (at 50,000 miles). Interestingly, one thing that
didn't make a difference was replacing the motor mounts, which were in pretty bad shape.
For what it's worth.
