I want to start by thanking everyone for help in advance.
So the whole story. We bought the car, 2003 Passat 1.8t, with a bad oil pump. Long story short we ended up replacing the motor. Well my father in law cause I’m less than confident doing so in a VW. Put new timing belt and tensioners in it and a new oil pump. Got it running again and it ran rough. Ended up putting a new tcm in it and somehow it started to run better. But ended up parked for 7 months through winter. I pulled it back out and dried the carpet. Fixed the leaks, and can I mention I’ve never been so frazzled as to how many spots an interior can leak from.
To current problems. Was throwing a multiple misfire code, cylinder 4 misfire code, and a knock sensor. Knock sensor I assumed was due to crap gas sitting in it. I replaced the coil on 4 and it ran great again. Until yesterday. I’ve been driving it the past few days and then yesterday I cleared the knock code. I had just put fresh 91 in it and was trying to run it some, cleared the code and as I pulled out of the parts store it started running awful, lost power and died. Went to crank it over and wouldn’t even grab. Just click like it wants to engage but won’t turn over. Battery was new when the motor was put in it last fall.
Called the guy who put motor in with father in law as he has experience with it and said could be the ground loosened or isn’t grounding well off the starter?
Thought? Any other spots to look?
Thanks again!
Cody
Thanks again!
Cody
