1 - 1 of 1 Posts
Checking to see if someone wants to buy it whole after I hit a deer, I might part it out on ebay, but I'll cut a deal for a PW member
Unibody appears to be straight, but probably not worth fixing (mileage ~120,00 i'll double check that)
Has:
Techtonics Tuning 2.5 inch Stainless exhaust + twin 3 inch slant cut tips that exit straight (trimmed bumper cover)
It has the 2.5 in stainless downpipe and a 3 inch stainless test pipe on it right now (all about 6-7,000 miles ago)
I had some flanges added in to make it easier to disassemble but they did weld the downpipe to the mid-pipe so I would have to cut it to ship it :(
a good running engine (needs new valve cover gasket/cam plugs and timing belt cover cracked on the top edge when the hood buckled)
Trans working fine but clutch is original
12,000 miles on new factory VW 1BE sport springs from Germany (~$1,000 new)
Bilstein HD (yellow) shocks at same time
Complete set of upper and lower control arms at the same time as shocks (brand? supplied by shop)
also new front sway bar links (just URO parts)
Audi RS4 motor mounts, polyurethane snub mount, rubber trans mount all about 9-10,000 miles)+1 trans mount I didn't get put in yet for the left
TSI ignition coils and aluminum spacer/adapter plates (6,000 miles)
Reusable Air filter (off brand that let less light through than K&N) in a modded stock air box (~COAM w 2 inch PVC pipe)
Brand new GKN (OEM) CV shafts (both sides 500 miles)
1 season on General Altimax arctic tires on stock steel rims (looks like brand new tread depth)
2 seasons BF Goodrich G-force Z rated tires on 16 in Audi speedline rims (2001 A4) (~75% of tread depth left)
extra gauges mounted on center dash are Prosport Performance series: Boost (mechanical), Oil Pressure (elect), Oil temp (elect)
It's missing: SAIP, glove box, headlights, cracked windshield, rad, AC condensor, PS resevior, rad support, headlights, hood, front fenders buckled
Pictures soon
Price is $2,200 firm, You can run it long enough to pull it up on your trailer at my place in La Crosse, WI,
Let me now if you're interested
1 - 1 of 1 Posts
