I will be adding a second battery with a relay isolator. I'd like to know of the locations of lines that are active only when the engine is on (not just accessory).
It seems the norm is to put the relay isolator in the engine bay, so I'm guessing I'll have to tap into something in the fuse box? Any particulars would be greatly appreciated.
If it's possible to put the relay isolator in the boot closer to the battery with no ill effects, then are there any ignition lines inside the cabin? I have the Monsoon system installed, but afaik there's only an accessory signal line involved.
