My sister's B5 does the same thing. I've heard cheap replacement axles are to blame because the shaft is too narrow, but since good axles are expensive, I haven't convinced her to replace them. Can anyone confirm?
Yes Zach. I installed the snub mount by accelarating few times And then i torqued the bolts.After you installed the engine mounts I think you are supposed to start up the engine to let it settle into place. Then proceed to torque the bolts on the mounts to the correct spec.
Did you do this?
Does this can vibrate my headlight beams at idle ?My sister's B5 does the same thing. I've heard cheap replacement axles are to blame because the shaft is too narrow, but since good axles are expensive, I haven't convinced her to replace them. Can anyone confirm?
