Ok so when I shut off the car to the position where I can remove the key a bunch of lights stay lit in the instrument cluster and a noise from the throttle body until I unhook the battery. I can even unplug the key switch and the lights stay on. if I hook the battery up, they all come back on, and I can start the car and it seems fine as long as the motor is running and it runs and drives fine. this car is kept inside almost always and has never had water inside. Any ideas would be greatly appreciated Thank You
