So my wife has a 2002 B5.5 Auto with a V6. Car has had engine issues recently but after working on it for 25 hours last weekend it was running better than it did when I bought it. Today she drove the car all over creation and it started / ran beautifully every time. We both were about to leave for dinner & a movie and the darn thing won't start. Won't even crank. Doesn't even try. With the evening cancelled, I dug into it. This car has never done anything remotely like this.
History:
1. Last weekend I replaced the passenger side head with a new one due to bad valves due to a bad cam chain tensioner. Everything went as planned, car has perfect timing. No CEL after clearing codes.
2. For a while now, when the key is turned to the off position but left in, the doors automatically unlock and the radio shuts off. It used to only do that when I pulled the key from the ignition
What I've checked:
1. Fuse 14 is good. Interior lights are on, gas flap opens, windows go up and down.
2. When turned to start, relay 185 clicks. Replaced it with a known good spare I have, and there was no change.
3. Tried jumping it with my work van, but it still does nothing.
4. Tried putting it in N to try and start it, same result.
5. Pulled relay 185 and jumped the 30 & 87 terminals. Nothing happens. (Will try this again tomorrow with a wire as the switch assembly I used might be faulty according to my multi-meter
Tomorrow I plan to take off the ignition switch and test it for continuity to see if maybe I need another one. I have read a lot of similar posts, but I am confused about which relay should have power and when. Thanks in advance for any help!
History:
What I've checked:
