1 - 2 of 2 Posts
Okay noticed today my automatic is leaking. Not from the pan or other seals but seems to be coming from the electrical plug area. I am on the road for work, so can't get a real good look but is there a gasket or seal that could be bad around that plug? Is it under pressure if so, or could I clear it up good and RTV around it.
Thanks
I would expect an O-ring, but I don't know offhand. RTV needs a clean/dry area to adhere to, so unless the pan is empty, it will not stick. Plan on a filter/fluid change, drop the pan and then replace the seal.
1 - 2 of 2 Posts
