I have a 2001.5 passat sometimes when I take off engine misses. When I check it the coil is loose. Coil number 2 is the one that comes off. Im going to switch coils and see if the same coil does the same thing. Has anybody had this problem? please help. Whats a B5 consist off .I see B5 is that a certain passat. is it the body style.:thumbup:
2001.5 - 2005 is a "B5.5", 1998 - 2001 (early) is a B5. "B5" refers to the "B" platform used by VW and it is the 5th generation of the Passat.
The easiest way to tell - the B5.5 has the two round circles on the taillights, and chrome trim around the windows. The B5 does not.
Not sure why the coil pops up. I noticed when I changed my plugs that sometimes the coil pack wound seat all the way in the hole, as it was a pretty snug fit. Thats all I can think of, although I know others have had the issue as well.
Had the same problem once, different cylinder. Turns out I did not torque the spark plug properly in that cylinder, the after a while the blow-by from the base of the plug would create pressure enough to push the coil up off the plug. Check the plug torque.
cool thanks ,anybody knows of good sparkplug, my is a 2001.5 which means
its b5 or b5.5 ? love my car but scared to run it hard do to the coil.does anybody know if its safe to run denso iridium spark plugs.
