Oh boy, your friend is VERY CORRECT :wink: . Honda motors have a HUGE after market following, so there are plenty of products that make boosting those motors just as reliable as any 1.8t. I had a civic hatch that I swapped a bone stock LS motor into. I then turbocharged it on 10psi. She made right at 260whp or about 305crank hp. I have since sold the car, but she is still running with perfect comp. to this day and burns NO oil. Its all in the tuning. Make sure he goes with hondata for engine managment or something that offers EMS capabilites. He needs to get bigger injectors and a Walbro 255lph fuel pump. Tell him NOT to use FMU's as they are very inconsistent and unreliable. Now, I made all of the power on a stock motor
, imagine what could be done on a built and sleeved motor. The average sleeve you put in those motors are designed to handle about 60psi of boost, so you dont' have to worry about cracking them from pressure 8) . Then you throw the forged rods and pistons in there and I would expect now less than 450whp on race gas and 350whp on pump gas. Oh, and as long as you have a good machine shop and build the motor to handle the rpms you will be revving, I would expect it to last a good 6years at those hp levels. Do note though, sleeving is very expensive. You have to buy a spare block and ship it to the sleeving company so they can install the sleeves. Then you have to get your forged rods/pistons. Then most people polish the crank and have everything knife edged and balanced. Then new bearings need to go in along with APR headstuds and in a lot of cases while the head is off, most people with get it ported, have a valve job done, and sometimes go on and build the head as well. Then replace with all new gaskets and whatnot. Once it is all said and done, you will drop about $6k on your average built motor and upwards of $10k on awesome setups. However, with $6k into your motor, you could handle 500+whp. With $10k, along the lines of 700+whp. Its all in the amount of $$$ you want to spend. However, your motor will always only last as long as how good your tune is, so make sure he doesn't skimp on fuel management
