I am replacing valve cover gaskets on my '05 GLX V6 after removing the passenger side cover I accidentally dropped the spring clip from the cam position sensor into the timing chain cavity. I tried to take out the camshaft and chain tensioner but the very last bolt I needed to get out I stripped the torx head. Of course this is the second to lowest bolt at the back of the engine and there is no room to get vice grips on the head. This bolt also needs to come out so I can replace the cam seal which is leaking. Does anyone have a suggestion on how to extract this bolt? I can't get a drill in to drill it out. Should I try to chisel it off?
After that fiasco I went after the drivers side. all was going smoothly until the final bolt tightening the cams back down and wouldn't you know I broke the final bolt below the surface of the engine block. Is there anything I need to know about prepping for bolt extraction?
Any advice is greatly appreciated. Thank you
