I am rebuilding the heads due to bent valves, and need a few torque specs. My head bolts are the T30, Non-stretch. Dont know if that makes a difference.
Specs needed:
Cam caps
Head bolts
Exhaust manifold
Intake manifold
Thanks!
I don't know if there are specs for non-stretch head bolts. I could try checking the torque on my old V6 to see what they come out to.
Ive been scouring the net for 2 days, the only specs I can find for the head bolts is this:
Head bolts: 44 ft-lbs, +90 degrees, +90 degrees
Also found these,
Intake & Exhaust manifolds: 18 ft-lbs
Cam Bearing Caps: 84 in. lbs (10 Nm, 7 ft-lbs)
Make sure you get new intake manifold gaskets. They tend to loose elasticity after a while and will not seal well after removal.
