1 - 1 of 1 Posts
I have 2 codes that might be related (from other posters/forums):
008328 - Bank 1 Camshaft A (Intake) Position Actuator
P2088 - 002 - Short to Ground
001681 - Fan 1 Control Circuit
P0691 - 002 - Short to GND
I need the wiring diagrams (2006 Passat 2.0T auto FWD, BPY engine) for both circuits.
Also: read that a blown fuse can have similar error?
When I unplug the camshaft actuator (driver side of engine, rear top), the code shows "circuit open".
While waiting for someone to help me out with wiring diagrams:
can someone post HIS measurements?
I measured at the cam adjuster connector:
- Key off, flat side pin, resistance to ground: 7.9 mega Ohm
- Key off, round side pin, resistance to ground: 13.7 mega Ohm
- Key off, voltage to ground both pins: 0 Volt
- key on, flat side pin, resistance to ground: 9.6 mega Ohm
- key on, round side pin, resistance ground: open/infinite
- key on, flat side pin, voltage to ground: 0 Volt
- key on, round side pin, voltage to ground: 3.1 Volt
1 - 1 of 1 Posts
