I have a 99 VW passat I had to replace the Comfort Control Module. It was filled with water and well destroyed it along with the pigtails I was able to to get new pigtails and a new CCM and was able to connect all the wires to new pigtails except for one wire. I am hoping someone has the wiring diagram of the CCM along with the wire coloring. Please Help!!!!
Please make sure you post in the correct forum per the sticky threads in the new members area, which you were supposed to read over and post there first. I moved this to the correct forum, the B5 area.
Per Bentley schematic 29/17, there is a red/yellow (red with yellow stripe) wire, 1.5 mm2 (about 14 AWG), on pin 12 of the CCM. It is the power feed from fuse S144, 15 amps; the fuse in on the 8-fold relay panel, not in the main fuse box.
FYI, the red/black wire on pin 15 is the power from fuse S111, also 15 amps, also on the 8-fold relay panel.
This assumes the care was made from August 1998 on.
It probably will start the car. The CCM has to energize a relay, signifying that the alarm is disarmed, in order for power to get to the starter. Thus a blown (or disconnected) power wire to the CCM will usually result in a no crank condition.
I don't have a diagram, but there are probably numbers molded in to the connector, if only in the four corners. It will be numbered either across-then-down or down-then-across, but you can figure that out from the four numbers. Also look at the mating connector in the CCM--the numbers may be easier to see there.
Alternately, search the forum for photos of the CCM connector and play match the colors. Also, in Post #4, I give the colors for pins 12 & 15, so you may be able to deduce it from there.
If all else fails, take a picture of your connector and I can compare it to the schematic.
Clarifying the wire color:
The base color is always listed first, then the stripe color.
For example, a red wire with a yellow stripe is "red/yellow" or maybe "red w/yellow."
Bentley schematic 29/17 shows three 0.5 mm2 wires from the 15-pin CCM connector to the Red 10-pin connector at the A-pillar (beside drivers left foot). I'll list all three here for ease of location:
15-pin CCM 10-pin Red Wire Color
Pin 8 Pin 1 Yellow/Red
Pin 9 Pin 2 Yellow/Green
Pin 2 Pin 2 Yellow/Brown
The odd thing is the schematic just stops at that connector, as if nothing connects to the other side. I believe the mating connector goes to the roof wiring harness, but I can't think of what the wires might be for. Maybe something not present on US cars.
Check the mating connector and see if there are wires there. If not, you can just cut and insulate.
Bentley schematic 29/17 shows three 0.5 mm2 wires from the 15-pin CCM connector to the Red 10-pin connector at the A-pillar (beside drivers left foot)<snip>
PZ (post #14) made me look, which found an error in Bentley.
Schematic 29 says the connector is red.
Schematic 51 says red on 51/17 but green on 51/18.
Schematic 82 says green everywhere.
The connector list on page W 97-3 says left A-pillar connector 3 (top right) from Floor to Roof harness is red.
I wouldn't be surprised if it changed somewhere along the way. I'd be only slightly more surprised if it were light blue.
Ok. Engine is running now I got another issues the vacuum lines on top of the throttle body are all jacked up anyone have a diagram or advice one what to do.
This link is so confusing. One picture will have the lines going one way and the next a extra hose appears and it's going somewhere else than where it's supposed to go.
New problem. The engine idles great and at high rpms runs great but there is a hesitation and revving in between. Code reader says throttle body malfunctioning. I cleaned the maf and the throttle body. I also looked to see if about getting a new throttle body but can't find the same one with two large brass fittings. What do I do?
I haven't read all the posts above but I assume you have taken out the TB and decarbonized it totally. If you have completely cleaned it up and it's not working then either the electronic module controlling it is not working or the TB unit itself is shot and needs to be replaced.
Related Threads
Volkswagen Passat Forum
3M posts
158.6K members
Since 2002
