When starting the throttle stays wide open and won't idle down. Got and idea about it but not sure
What's your idea about it? Also, please give us as much relevant (and maybe irrelevant) info on the car as possible. There may be something you have done to it recently to cause this.
Reactions: axenstar
It's a cable throttle, so look for issues with the cable. Rust, sharp bends, stuck floormats....
Reactions: VAGguy
I punched the pedal to pass a car and it stuck wide open
Make sure the cable is in place in the throttle body. Sometimes it comes out or gets stuck in the actuator when you slam the gas pedal leaving the throttle stuck open.
