Hi Everyone :wrench:.
Just bought a 1998 1.8 T 5 speed manual with 140K miles. The only thing the seller knew about it was it had a new clutch put in at 120K miles and the oil was changed at Jiffy Lube. :hmmm: Very clean original condition inside and out. Has all the original emergency kit, spare tyre, tool kit and even the original floor mats. It had not been driven in months. It started right up when I went to look at it. The test drive was around the block as the temperature gauge was not working. The drive home was about 8 miles. The temperature sensor was installed yesterday which gave me the vitals to take it for a good drive. I have an engine knock. :banghead:
Well here's the symptoms. It knocks for a second when cold starting till oil pressure builds. It remains quiet when cold no matter what you do. When it reaches operating temperature it doesn't make any noise till I reach about 4000 RPM or when there is no load in gear going down the highway. There is no knock at any time when idling. There is knock at 2000 RPM and higher in the garage. Pulled the tupperware off yesterday and it has leaks on the bottom end of the block only. Top end is clean. The power is equivalent to a 60's single port 1200 cc beetle.
I have purchased new seals and gaskets for it (excluding rear main, head gasket and sump pan). New turbo as I read that these have a tendency to fail at the wastegate. New belts all round with tensioners.
I am assuming the worst case which is rod bearing gone bad. Unless someone with a little more experience with these engines can tell me otherwise.
