So, about a year ago, I repaired my head (valves, timing belt, water pump, tensioner, etc.)
Everything went perfect, and it runs great. However, it doesn't always start on the first try. Sometimes two tries, sometimes seven. Cranks, just doesn't fire. And when it does start and is at idle, the idle jumps from 7-800, up and down. I also get a p0340 code all the time (camshaft timing sensor). I already changed the sensor with a brand new one, and checked the wiring. All looks good.
Again, she runs great, but something is off.
I just checked my timing marks on the cam and crank pulley. It's perfect. Took the valve cover off, and the marks on the cams versus the journal arrows look almost perfect, but I can't tell if I have sixteen teeth on the chain or not. I'm not an expert at that. Anyone know if that would be the problem?
