1 - 2 of 2 Posts
Hey guys. Just wondering if anyone can give me advice on my fault codes. (I'd also gotten one a while back for my low pressure fuel pump but that's gone, although I can still smell gasoline at times when I start up the car)
Address 01: Engine Labels: 06F-907-115-AXX.clb
Part No SW: 3C0 907 115 S HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0020
Revision: 5BH16--- Serial number: VWZCZ000000000
Coding: 0404010A19070160
Shop #: WSC 08284 444 58853
VCID: 306F338FA31E5EC159-8064
4 Faults Found:
001152 - Coolant Fan Control Circuit 1
P0480 - 002 - Electrical Malfunction - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 50
Reset counter: 255
Mileage: 206412 km
Time Indication: 0
Date: 2017.03.19
Time: 20:38:01
Freeze Frame:
RPM: 1662 /min
Load: 37.2 %
Speed: 29.0 km/h
Temperature: 80.0°C
Temperature: 49.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 13.843 V
004372 - Oxygen (Lambda) Sensor; B1 S2
P1114 - 008 - Internal Resistance too High - MIL ON
Freeze Frame:
Fault Status: 11101000
Fault Priority: 2
Fault Frequency: 18
Reset counter: 255
Mileage: 206753 km
Time Indication: 0
Date: 2017.04.05
Time: 10:23:03
Freeze Frame:
RPM: 770 /min
Load: 25.9 %
Speed: 0.0 km/h
Temperature: 67.0°C
Temperature: 20.0°C
Absolute Pres.: 1020.0 mbar
Voltage: 14.478 V
008577 - Performance Malfunction in Cooling System
P2181 - 008 - - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 18
Reset counter: 255
Mileage: 206753 km
Time Indication: 0
Date: 2017.04.05
Time: 10:23:03
000313 - Oxygen (Lambda) Sensor B1 S2
P0139 - 004 - Response too Slow - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 2
Fault Frequency: 9
Reset counter: 255
Mileage: 207941 km
Time Indication: 0
Date: 2017.06.09
Time: 21:42:38
Freeze Frame:
RPM: 1333 /min
Load: 12.2 %
Speed: 52.0 km/h
Temperature: 87.0°C
Temperature: 48.0°C
Voltage: 14.224 V
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000004892646
Coding: 00848F0340041A00470000000F000000000854415C0001
Shop #: WSC 00028 028 00001
VCID: 6CD7E7FF4FB6FA2125-8038
Subsystem 1 - Part No: 3C1 955 419 A Labels: 1KX-955-119.CLB
Component: Wischer 230407 003 0205
Coding: 00046997
Shop #: WSC 00028
3 Faults Found:
01504 - Bulb for License-Plate Light (X)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00111100
Fault Priority: 2
Fault Frequency: 3
Reset counter: 92
Mileage: 208152 km
Time Indication: 0
Date: 2017.06.18
Time: 20:04:00
Freeze Frame:
OFF
Voltage: 12.60 V
OFF
ON
OFF
OFF
OFF
00978 - Lamp for Low Beam; Left (M29)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 92
Mileage: 208152 km
Time Indication: 0
Date: 2017.06.18
Time: 20:04:00
00979 - Lamp for Low Beam; Right (M31)
Freeze Frame:
Fault Status: 00101010
Fault Priority: 1
Fault Frequency: 254
Reset counter: 98
Mileage: 199101 km
Time Indication: 0
Date: 2016.08.14
Time: 01:27:00
Freeze Frame:
ON
Voltage: 13.40 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 N HW: 3C0 909 605 N
Component: 17 AIRBAG VW8R 032 2522
Revision: 13032000 Serial number: 003B2P820RWO
Coding: 0012599
VCID: 3169368BA81457C956-8064
Subsystem 1 - Part No: 3C0 959 339 B
Component: BF-Gewichtsens. 007 0003
Subsystem 2 - Serial number: 0000000003LQQR
Subsystem 3 - Serial number: 0001.01.000000700000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†6332MSME1A244A63Bÿ†63
Subsystem 5 - Serial number: 44A63Bÿ†6342MSME19431E206ÿ†63
Subsystem 6 - Serial number: 31E206ÿ†6351HTS66HBGTLR6Dÿ†63
Subsystem 7 - Serial number: GTLR6Dÿ†6361HTS66HBGHNO61ÿ†63
Subsystem 8 - Serial number: GHNO61ÿ†63727TS6OFJSKLS6Yÿ†63
Subsystem 9 - Serial number: SKLS6Yÿ†63827TS6OFJOK6C60ÿ
Subsystem 10 - Serial number: OK6C60ÿ
1 Fault Found:
03032 - Supply Voltage for Seat Occupied Recognition Control Module
002 - Lower Limit Exceeded - Intermittent
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 3C0 907 801 J HW: 3C0 907 801 J
Component: J540 EPB3 VW-09393 0009
Revision: 008 Serial number: 00000000015067
Coding: 0000057
VCID: 2959DEEB80C42F099E-807C
1 Fault Found:
00532 - Supply Voltage B+
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 222
Mileage: 207609 km
Time Indication: 0
Date: 2017.05.16
Time: 02:44:09
Freeze Frame:
Voltage: 8.10 V
Count: 50
Speed: 14.0 km/h
Hex Value: 0x1260
Hex Value: 0x0004
Hex Value: 0x0101
I dont have the precise info pertaining to the code. Smelling gas at start up could be a world of issues. If out the exhaust fuel laying in the chamber could seep pass a bent or carbon coated valve and sit in the ex. manifold until start. could be carbon in the intake blocking some direct injection fuel. If smells from the front (engine). Could be PCV, which would also be directly responsible for the intake carbon. Could be injector seals. a fuel leak. problem with the high pressure pump. Or O2 sensor problem will mostly be from your fuel issue running too rich. I know these are very vague. I hope it could help
1 - 2 of 2 Posts
