1 - 10 of 10 Posts
· Never mind me, I'm lazy!
Hello Folks,
I have compiled a list of parts after reading through the previous threads.
http://www.passatworld.com/forums/showthread.php?t=256898
http://www.passatworld.com/forums/showthread.php?t=310668&highlight=PCV+ETKA
06B 103 245 - "T" shaped bleeder valve
-N 102 581 01 - clamp
-N 907 399 01 - hose clip
058 133 753 D - "Y" shaped crankcase breather valve
06A 129 101D - PCV Valve
N 907 399 01 - hose clip * 2
06A 103 213 F - Breather Tube
-N 904 673 01 - round seal
-06B 121 142 A - retaining spring
058 129 717D - Intake Manifold Gasket
I have two questions.
Am i missing anything?
Is it possible to replace -N 907 399 01 - hose clip with a screw type clamp?
Thanks a lot in advance. :)
Som
I'd also change out:
035 103 245A - PCV Valve
It's located further down and the wider part is actually clamped into a hose. Mine had some gunk inside of it.
Personally, I changed out all the one time use clips to the screw type clamps. As long as they are the right size I don't see any problems in the future.
I dont see the part anywhere in the diagram
http://i21.photobucket.com/albums/b261/bklymus/awm-pcv.jpg
Also searched ecs it says that its upto 2002. Can you shed some more information on this.
I have another problem, i cant find the part number
anywhere in the car. It was not there in the diagram also.
Whereas i have the pcv valve part number 06A133528A (number 25 in the diagram) which i am replacing as we speak. Is it true that the Y shaped suction pump is no longer there in 04 AWM 1.8T. Thanks.
http://xyrotr1.com/etka/B5.5/1 engine, clutch.pdf
^^^^ Check this link, it's on page 81, part #19. For whatever reason it isn't in the diagram that I posted that you linked too. If you're looking under the hood it is near the firewall, right behind the intake manifold, about 4 inches long. I have an 04 AWM, so it certainly is there.
Discussion Starter · #9 ·
This is what i had ordered to change it.
06B 103 221 F - hose
06A 103 247 - valve housing
N 907 399 01 hose clip * 2
06A 103 213 F - Breather Tube (aka elbow to oil cooler) -
-N 904 673 01 round seal
-06B 121 142 A retaining spring
- N 907 399 01 - clamp
058 129 717D - Manifold Gasket
You would also need a set different size of screw type hose tighteners to replace the ottikker clips which you will remove. They are available from any autostore
1 - 10 of 10 Posts
