Well guys I'm at my wits end with this no fuel problem. I checked fuse 28 good, Read some where here if you get a blink on your test light at 28 when cranking that means everything upstream good. I had no sign of it trying to run at the pump so I replaced it still no fuel. I 'm trying to get at the relay panel can't figure out what's holding the lower panel under steering column. I got the 2 star bolts on the door side but can't fine anything on the other side I laid under the column I saw a metal strap looking thing on the other side at the bottom but that's it. Afraid to pry on any thing don't want the break the plastic. Should I have 12 volts at the pump on pin 1&4 key on ? Also there is 2 2 pin connectors on the bottom of the pump top plate . Does it make a difference which one goes on witch one. I no fuel gauge working so I'm assuming i have them reversed. HELP PLEASE :confused:
there are two more, one on each side of the steering column, you kinda have to look up at a 45 degree angle from the bottom of your front seat.
I will run and a grab a photo.
This one is on the far right, almost touching the center console.
Up is to the right in the photo
This one you should be able to tell by the photo where it is (in the little cut out)
Tomvw hello the volts at fuse 28 was 11.6 when cranking.Quick flash then gone. new fuel pump and 11.5 at the pump connector pin 1 &4 pump won't run.
