I'm sure this is covered somewhere in the forums but I haven't been able to locate it. I was wondering what the best brands of some replacement parts would be on my fiance's 03 Passat V6 4Motion. I think a previous owner installed aftermarket CV axles since the car starts vibrating when it hits about 60-65mph. I found out that most of the "replacement" and rebuilt ones have a solid shaft instead of the OEM hollow one, does anyone have advice on finding the best replacement ones so I don't end up doing this again in a year? So far I'm thinking Raxles is the way to go....
Second is I have to replace the valve cover gasket. It has a very small leak, but that falling onto the hot exhaust makes an awesome smell in the car when it's not moving. I found Beck/Arnley gaskets fairly cheap, but cheap that can also bite me in the a$$ later so hopefully someone knows of the best OEM ones I should use.
I've been scared of replacement parts for VW since my issue with my 2000 Jetta. I got a replacement timing belt that was just barely too small and finally figuring that out made me never order from that site again....Thanks in advance.
