1 - 2 of 2 Posts
ok.. picked up 01 passat automatic at an auction. the headlights do not turn on, yet i can flash brights by pulling lever toward driver seat. the turn sygnals dont work yet the hazzards do... and the blower is not working even tho i can hear the compressor making noises when i change from defrost to floor to panels. Any Ideas? oh and the turn signals and the blower were working when i drove it home from auction. I am unsure of headlamps as it was daytime. The battery was dead next morning , I jumped it and it was dead again the next morning so i swapped it out yesterday. I have replaced all fuses.
2001 B5 or B5.5 ? Is the car damaged in any way?
I guess you have figured from the dying battery that you have a short somewhere ...
Did you check with a volt meter ALL fuses on the fuse panel? If any burn again, then you have a pointer where at least one problem is.
By the way - Check if your glove box light turns off when you close the glove box?
1 - 2 of 2 Posts
