A properly working fan should not squeak, ever.
You'll have to check the Freon charge level / pressure in the a/c system.
A system that is below the minimum required pressure won't allow the a/c compressor to kick in.
Also, check to make sure the a/c fan (electric fan behind the radiator) is spinning fast enough to pull the heat out of the condenser so that that the a/c system can operate properly. If the electric fan doesn't spin fast enough the a/c system will overheat and cause the system to 'slug' which can bog down the engine, so much so it can kill the engine at idle.
