Front sway bar replacement
Results 1 to 2 of 2
    Mar 2019
    6
    My wife has a 2012 S model with the 2.5L 5 cylinder and one of the brackets that mounts the sway bar to the subframe broke. You can't replace just the brackets because of piss poor design (bracket is welded around the bushing) so i bought a replacement sway bar. From what I'm reading, I'll need to drop the subframe to get the old bar out and likewise, get the new bar in place. Just curious if anyone has any tips or tricks? I found info on other models but info is limited on these Passats. I'm wondering if i can just loosen the subframe to drop it enough to wiggle the bar out or if I need to completely drop it. I'll figure it out either way but I figured I'd ask. I tried searching and like I said, can't really find anything specific to this car and I'm not sure how similar it is working on the various models as I'm not a VW guy. If anyone has any tips for this DIYer or can point me to a thread with info on this, I'd appreciate it.
    Thanks
    Mar 2019
    6
    Just wanted to report back that I completed this job. It actually went pretty smoothly except for the fact that most of the bolts mounting the sway bar to the subframe snapped off when I tried to remove them. Dropping the subframe is pretty straight forward. Just make sure you buy new subframe bolts as they are stretch bolts. I did not realize this until the night before I did the work when I was reviewing some info so I did the job and then bought bolts from the dealer the next day and replaced them 1 by 1. These are the part numbers I needed.
    N-911-433-01 (2 of these bolts)
    N-912-084-01 (4 of these bolts)
    I found the torque specs online and used 70 NM (52 ft/lbs) plus 180 degrees. Car feels amazing now! I had a major clunking going on and I think it was the subframe clunking around. I also replaced the endlinks.
    All in all, not too bad of a job. I still think it's completely ridiculous that they designed it so that you have to replace the entire bar when a bracket fails but it doesn't surprise me on these silly cars.
    Just note that the stretch bolts for the subframe are extremely expensive. It cost me over $50 from my local dealer for the 6 bolts. I'm sure they can be found online for a little bit cheaper though.
  4. Remove Advertisements
    Similar Threads
    1. 1BE 4 motion 17mm rear sway bar and aftermarket front sway bar
      By passatboy02 in forum WTB/WTT Section
      Last Post: 08-31-2015, 04:30 PM
    2. FS Nuespeed 28mm rear sway bar. 1BE front bar.
      By PZ in forum Classified Archive
      Last Post: 03-29-2005, 07:15 PM
    3. O-Bar/ P+P Motorsport Rear Sway Bar 50.00 + shipping
      By ------TJ------ in forum Classified Archive
      Last Post: 07-06-2004, 08:10 AM
    4. Which is Better: Rear Sway Bar or O-Bar?
      By defector in forum Volkswagen Passat B5 Discussion
      Last Post: 01-19-2004, 06:59 AM
    5. FS: OEM Clear Corners and O-Bar/P&P Rear Sway Bar
      By IslandT in forum Classified Archive
      Last Post: 03-24-2003, 01:54 PM
