Oil Pressure STOP warning 2001 V6
Results 1 to 13 of 13
Like Tree5Likes
  • 1 Post By AndreasPassat
  • 2 Post By Hirnbeiss
  • 2 Post By John_E
Thread: Oil Pressure STOP warning 2001 V6
    Jan 2019
    Oregon
    9
    2001 Passat GLX V6 95K
    I’ve had this car since 2004 and for the first time ever the dreaded Oil Pressure light screamed at me today. I’ve researched this question here but this incident is different than others I’ve read about.
    In my case I was driving some curvy roads on the way to the coast at a slightly above average speed (30-40 mph on 20-30 mph curves). I hit a couple of these curves in quick succession and was decelerating when it went off. I slowed down and within 15 seconds the light vanished. The car operated properly throughout.
    So, any thoughts if this is something to be concerned about? Oil level is good and vehicle has always had synthetic oil.
    Jul 2013
    Chagrin Falls,Ohio
    1,181
    usually it's the 1.8s with oil "sadness" however ,obviously you checked the oil (dipstick) .....couple things ,whats the mileage? and oil used? ,Oil pan is easy to drop to take a "looksie" at oil pick up tube , might be partially clogged from years of detritus ......,someone can chime in 'cause I cannot remember if they (2.8s) have a windage tray.
    Jul 2013
    Chagrin Falls,Ohio
    1,181
    dah,just saw mileage ,sorry
  5. Remove Advertisements
  6. #4
    Jul 2013
    Chagrin Falls,Ohio
    1,181
    and oil....... , what weight?
  7. #5
    Overdrive
    Feb 2007
    Lehigh County, Pa.
    64
    12,058
    Oil pressure light during lateral acceleration implies low oil level. What's the dipstick read? Was it measured on a flat surface? Is it the right dipstick for the car?
  8. #6
    Jan 2019
    Oregon
    9
    The stick, which is correct for the car, reads a quart low on flat surface. Will add and see what happens. Thank you!
  9. #7
    4th Gear
    Jul 2006
    Phoenix, AZ
    52
    4,060
    If the car is only a quart low it shouldn't trigger the light.
    By any chance do you have the low oil sensor on the very bottom surface of the oil pan? Those sensors are known to fail and give false readings.
    Look for this sensor on the bottom of the oil pan. Can't miss it. If there's a sensor, you have low oil sensing option on your car.
    If the sensor is not there, you don't have that option.
    jjpark likes this.
  10. #8
    PZ
    PZ is offline
    Redline
    May 2002
    Grapevine TX. 01 4M
    56
    25,840
    I've had the light come on several times on my vehicles during hard turns. I tend to take them at well above normal speeds and when the car is 1L low, it will trigger the low level sensor.
  11. #9
    Jan 2019
    Oregon
    9
    Quote Originally Posted by AndreasPassat View Post
    Not sure but I’ll check when I get home. I’m suspecting that the sensor is working properly.
  12. #10
    Jan 2019
    Oregon
    9
    Turns out I was about 1.5 quarts low so thinking this was the issue.
  13. #11
    2nd Gear
    Jun 2014
    S. Florida
    970
    We’ll go with oil level was too low for now, but the fact that it surprised you (you initially said level was good) is concerning. I would change the oil with a quality filter and then monitor consumption with the dipstick more frequently. Chances are good you’re due for a PCV refresh and valve cover gasket replacement.
    cchief22 and kwarren1079 like this.
  14. #12
    5th Gear
    Oct 2004
    Encinitas CA
    5,394
    This is also a good time to check your coolant recovery system cap for oil contamination from a bad oil cooler (extremely common problem).
  15. #13
    Jan 2019
    Oregon
    9
    Thank you all, it’ll be in the shop by the end of the week.
  16. Remove Advertisements
