P0431 P0421 codes
Results 1 to 9 of 9
Like Tree6Likes
  • 1 Post By Emry
  • 1 Post By PZ
  • 1 Post By Btitans
  • 3 Post By RCinSTP
Thread: P0431 P0421 codes
    Aug 2010
    Saint Paul, MN
    314
    P0431 P0421 codes
    I'm getting codes
    P0431 Warm Up Catalyst Bank 1 Efficiency Below Threshold
    P0421 Warm Up Catalyst Bank 2 Efficiency Below Threshold
    where do start for diagnosing? It looks like both driver and passenger side, but, do these codes relate to Upstream (before the Catalytic Converter?) or Downstream (after the cat)?
    Is there a way to test the O2 sensors, because if the sensor is bad, I will replace it, if the sensor is good, I will add a spacer. Would O2 sensors on both sides go bad at the same time?
    Jul 2007
    Michigan
    56
    2,172
    Quote Originally Posted by RCinSTP View Post
    Do you have a scanner to read the live O2 sensor values?
    Very unlikely that both go bad at the same time. Nevertheless, that is not the issue here. Just get the values and see if they indeed gone bad.
    RCinSTP likes this.
    PZ
    PZ is offline
    Redline
    May 2002
    Grapevine TX. 01 4M
    56
    25,839
    These are for the downstream sensors. It could be bad flex pipes as that allows air into the exhaust.
    If the flex pipes are good, just add spacers to the rear O2 sensors. On earlier V6 engines, there was a software update as the parameters were (supposedly) set too low.
    RCinSTP likes this.
  5. Remove Advertisements
  6. #4
    Feb 2019
    Vermont
    124
    age/mileage?
    o2 sensors ever been replaced?
    cats ever been replaced?
    I thought you got the 2096 and whatever the other side error is when you have flex pipe hole issues...4031/4021 usually was 02 sensors.
  7. #5
    Aug 2010
    Saint Paul, MN
    314
    I don't have have access to the car right now, but as soon as I do, I will check things and reply back. I just happen to have some spacers so I might start with adding spacers and then check the VCDS Vag-Com software again. The flex pipes are a bit worn but still solid and seem to be sealed tight.
  8. #6
    Apr 2011
    NY
    18
    Leaks most likely at the flex joints. You can start it cold and run your hand around joints, you should feel something before it gets too warm to touch.
    RCinSTP likes this.
  9. #7
    Aug 2010
    Saint Paul, MN
    314
    Thanks, Btitans, I appreciate the tips about the flex pipes. I wanted to know how they could be checked for leaks.
    Thanks, Emry, PZ and ar393, I didn't realize how much could be checked with the VCDS (VAG-COM) software, I generally just use it to look for fault codes.
    I turns out that the Fault codes were caused be one of the cylinders misfiring. I completely forgot that I couple of months ago, this same car (my wife's car), had the #2 cylinder spark plug wire go bad. I checked the software and just like last time, one of the cylinders was misfiring a lot. I replaced that plug wire (the wire that runs from the coil pack at the front of the V6 engine, to the spark plug), and the car has been running great since then, no mis-fires.
    I plan to buy a set of high-quality plug wires and replace all the wires.
    Thanks again for your help and advice.
    cchief22, PZ and Emry like this.
  10. #8
    Feb 2019
    Vermont
    124
    Hehe, I need replace my #2 Cylinder wire now myself. At some point down the line I may get some higher end wires.
  11. #9
    Jul 2013
    Chagrin Falls,Ohio
    1,181
    have to chuckle......it's like my car is reading/listening to these posts, I'll read something about .............vacuum leaks and misfires as an example..... and on the way home I get misfires/vacuum leaks......,however glad you got 'er solved
  12. Remove Advertisements
