Losing oil from the back of engine
Results 1 to 10 of 10
Like Tree5Likes
  • 1 Post By RAH
  • 2 Post By Emry
  • 2 Post By AndreasPassat
Thread: Losing oil from the back of engine
    Jul 2007
    Michigan
    56
    2,094
    I went to check the CTS for the coolant loss and noticed oil on the back of Kombi valve. Not sure where this oil coming from. Here are some pictures. Any hint or help is welcome. Thanks.
    4th Gear
    Jul 2006
    Phoenix, AZ
    52
    3,984
    Cam seals or valve cover gaskets or CCT gasket are the biggest likely culprit.
    Any way to get a clearer picture and one of the backside of the engine?
    Jul 2007
    Michigan
    56
    2,094
    Quote Originally Posted by AndreasPassat View Post
    Checked the valve cover gasket and it was dry around it. But as you said it may be either Cam seal or CCT gasket. Not sure how hard it is to replace them. I'll try to take a picture from the back of engine but it is a tight area.
  5. Remove Advertisements
  6. #4
    Jul 2007
    Michigan
    56
    2,094
    Also I saw the oil coming out is kindda fresh. This cannot be the engine oil because my engine oil is old and very dark. So could it be that power steering line is leaking?
  7. #5
    4th Gear
    Jul 2006
    Phoenix, AZ
    52
    3,984
    Quote Originally Posted by Emry View Post
    That is entirely possible. I'd keep on eye on that power steering fluid level. Our cars don't like low levels of power steering fluid. The pumps burn up pretty easy when low on oil.
    I'm making that comparison to say an old Chevy or Ford where you could almost run those empty for weeks on end, dump some fluid in and all is good.
    On our cars, as soon as you hear the power steering pump whining or groaning, get some fluid in it!
  8. #6
    RAH
    RAH is offline
    5th Gear RAH's Avatar
    Oct 2003
    Puyallup, WA
    5,850
    the spot where you are losing fluid could also be your steering rack. They have tendency to go bad as well. They are in the fire wall so you can look at the rubber seals on the rack to see if you are losing any in there, or at the steering pump.
    AndreasPassat likes this.
  9. #7
    Jul 2007
    Michigan
    56
    2,094
    Quote Originally Posted by RAH View Post
    I thought the steering pump is in the front of the car, isn't it? But I should certainly look at the steering rack as you suggest.
  10. #8
    Jul 2007
    Michigan
    56
    2,094
    Crawled under the car today and discovered that the leaking oil is indeed from the tranny pan. Turns out that I had not tightened a couple of bolts a few weeks back when I changed the ATF and the oil was coming out of those bolts. Tightened them and oil leak is gone for now. Thanks for suggestions and support though.
    VAGguy and John_E like this.
  11. #9
    4th Gear
    Jul 2006
    Phoenix, AZ
    52
    3,984
    Nice, an easy fix and a happy ending. A phrase uncommon with owning a Passat.
    VAGguy and Emry like this.
  12. #10
    5th Gear
    Oct 2004
    Encinitas CA
    5,374
    ... I'd keep on eye on that power steering fluid level. Our cars don't like low levels of power steering fluid. The pumps burn up pretty easy when low on oil. ...
    Don't ask me how I know that, or why the 1996 A4 is on its second power steering pump.
  13. Remove Advertisements
There are currently 2 users browsing this thread. (1 members and 1 guests)
  1. Dr No
Similar Threads
  1. Guess who's back...back again. AJ's back....tell a friend.
    By mcseforsale in forum Volkswagen Passat CC Discussion
    Last Post: 09-06-2015, 06:14 PM
  2. Oil Smell when running heater and losing oil
    By DarExc in forum B5 Garage
    Last Post: 10-30-2010, 10:10 AM
  3. LOSING oil...what can it be??
    By vdubplaya in forum Volkswagen Passat B5 Discussion
    Last Post: 12-16-2006, 09:44 PM
  4. Losing Oil Again!
    By 1Big Ed in forum Volkswagen Passat B5 Discussion
    Last Post: 07-26-2003, 12:33 PM
