'02 4Mo GLX Wagon, Front ABS/WSS "depth"
Results 1 to 8 of 8
Like Tree3Likes
  • 2 Post By cuppie
  • 1 Post By AndreasPassat
Thread: '02 4Mo GLX Wagon, Front ABS/WSS "depth"
    Feb 2019
    Vermont
    118
    Can anyone tell me how far away from the ring the sensor is supposed to sit? or how much space there should be (exposed silver part)?
    I had swapped the ABS/WSS and now I have the ABS kick on at the very end of braking......which from what anyone has told me has to do with the sensor being too far in or too far out....
    Thanks all
    2nd Gear cuppie's Avatar
    Dec 2015
    Detroit, MI
    645
    It's too far out.
    Generally accepted 'best practice' around here is to push the sensor in until it stops, then back it off *just* a smidge.
    Too far in (read: contacting the tone ring, on the CV joint) will grind the end of the sensor off.
    Too far out nets you a dropped signal, especially at very low speeds (like, almost-stopped.)
    Also, make sure that the tone ring is reasonably clean; blow off w/ compressed air as necessary.
    cchief22 and khnitz like this.
    5th Gear
    Sep 2002
    Fallbrook CA USA
    5,131
    I've never done anything other than push the sensor into the retainer until it stops, and leave it there. By design it should not touch the ring, however just a little deformation of that tone ring could lead to interference.
  5. Remove Advertisements
  6. #4
    4th Gear
    Jul 2006
    Phoenix, AZ
    52
    4,002
    Quote Originally Posted by ylwagon View Post
    You are correct, but some people don't live in the nice rust free environment and just pushing the sensor in is more of a task. On one of my cars the wheel speed sensors were so tight I thought it was threaded in.
    When it's all rusty and corroded it's hard to tell when to stop.
    ylwagon likes this.
  7. #5
    Feb 2019
    Vermont
    118
    Quote Originally Posted by AndreasPassat View Post
    You are correct, but some people don't live in the nice rust free environment and just pushing the sensor in is more of a task. On one of my cars the wheel speed sensors were so tight I thought is was threaded in.
    Car lived a lot of its life in CO and then in VT for the last few years. Then it sat...outside...in VT...from September 2018 until almost March 2019.
    Getting the sensors out to clean them and the tone rings was almost a 4 hour task.
    Tone rings are clean. Must just be that they are not far enough in.
    Next chance I get I will get at it with a plastic dead blow hammer and nudge it in, take a drive, if same issue, repeat until its good.
    I will make a mark or two with a sharpie so i can confirm that it is moving.
    Also will use my ramps so it doesn't become an all day project.
  8. #6
    Dec 2015
    Detroit, MI
    645
    I would suggest skipping the hammer..... You're likely to break the sensor.
    Take the sensor back out. Clean the hole out - Dremel, with a sanding drum, works well. Be sure to blow out (compressed air) the debris.
    The sensor should just push in, without much effort.
  9. #7
    Feb 2019
    Vermont
    118
    https://www.amazon.com/Performance-T.../dp/B01GGV1URI
    12 oz dead blow, without taking the wheel off, is not going to break anything.
    if I can find the time to grind/sand the "socket" I will, but that's gonna be tough.
  10. #8
    5th Gear
    Sep 2002
    Fallbrook CA USA
    5,131
    It may sound crazy, but I'd heat some vinegar to boiling, and slowly pour it onto that sensor retainer. The rust may dissolve enough to pull the retainer out entirely, then soak the thing in the vinegar to remove the remaining rust. Finish with a light coat of anti-rust paint.
  11. Remove Advertisements
    Similar Threads
    1. What All Do I Need For Timing Belt Change - 02 Passat GLX 4Mo Wagon V6
      By McE in forum Volkswagen Passat B5 Discussion
      Last Post: 01-03-2014, 08:25 PM
    2. Was this your car? ('02 GLX 4mo Tip Wagon, Chicago area)
      By Darter in forum Volkswagen Passat B5 Discussion
      Last Post: 03-18-2013, 08:21 AM
    3. 02 GLX.4Mo - Tune Up/ABS Mod Questions
      By FoMoPass in forum B5 Garage
      Last Post: 03-22-2011, 08:58 AM
    4. Setting ABS Sensor Depth????
      By Copo-Rat in forum Volkswagen Passat B5 Discussion
      Last Post: 06-03-2010, 09:21 AM
    5. o2 sensor "depth"
      By jti306 in forum B5 Garage
      Last Post: 07-18-2008, 03:37 AM
