car "shudders" when idling at stop light
Results 1 to 10 of 10
Like Tree3Likes
  • 1 Post By ar393
  • 1 Post By Emry
  • 1 Post By RCinSTP
Thread: car "shudders" when idling at stop light
    Aug 2010
    Saint Paul, MN
    311
    2002 V6 ATQ, GLX 4-Motion, auto trans (tiptronic)
    I replaced the MAF sensor and the Engine Speed Sensor/Crankshaft Position Sensor (CPS) because, while driving, the car would suddenly act as if the ignition was switched off and then quickly back on.
    That is no longer happening, but now, when idling, the car will shudder now and then. It does not shudder every time the car is idling. In a 20 minute drive it might happen 5 or 6 times. I don't know if this is related but the car sat outside in a heavy rain the other day and the floor mats on the drivers side were wet --but-- I checked the drainage tube from the sun roof and it is clear and the end is cut open in the drivers door opening area. The floor mats may have gotten wet from getting in and out of the car when it was wet outside. I lifted the floor mat and the electronics and everything under the drivers side carpet seems fine and totally dry.
    I have the codes below. I deleted the sections that had No Fault Code found. Any ideas of things to check? Things to test? Could I have gotten a bad CPS? Or maybe I installed the CPS wrong? I re-used the shim that was on the CPS that I took out, maybe the shim needs to be removed? Or a different thickness? Should I try to measure something to determine the shim thickness?
    VCDS-Lite Version: Release 1.2
    Thursday, 16 May 2019, 10:08:04:63159
    Chassis Type: 3B - VW Passat B5
    Scan: 01,02,03,08,15,16,17,19,35,36,37,46,47,55,56,57,58 ,75,76,77
    Address 46: Central Conv. Labels: 1C0-959-799.LBL
    Controller: 1C0 959 799 C
    Component: 09 Komfortgerát HLO 0001
    Coding: 00258
    Shop #: WSC 00028
    VCID: 37015E680655
    2 Faults Found:
    00913 - Window Regulator Switch; Front Right Driver (E81)
    27-10 - Implausible Signal - Intermittent
    01358 - Internal Central Locking Switch; Driver Side (E150)
    Address 56: Radio Labels: 3B7-035-1xx-56.LBL
    Controller: 3B7 035 180
    Component: Radio NP2 0005
    Coding: 04031
    Shop #: WSC 00028
    VCID: DDCD6CC04429
    4 Faults Found:
    00849 - S-contact at Ignition/Starter Switch (D)
    78-10 - Missing Messages - Intermittent
    01326 - Control Module for Multi-Function Steering Wheel (J453)
    49-10 - No Communications - Intermittent
    01064 - Terminal 58d; Interior Dimming
    00625 - Vehicle Speed Signal
    Feb 2019
    Vermont
    84
    Mine shudders once in a while when its been raining. mine is an occasional misfire on cylinder 2.
    does your engine light flash if you gas it while its shuddering?
    RCinSTP likes this.
    Jul 2007
    Michigan
    55
    2,061
    Based on the fault codes, there is definitely something wrong with the CPS as it sends intermittent. You need to check a few things here. First, the correct CPS should be used. Second, it must be sitting correctly in its place. Third, the grey harness should be tightly connected to it. If all these three conditions are met then you should not get the fault code.
  5. Remove Advertisements
  6. #4
    Aug 2010
    Saint Paul, MN
    311
    ar393: I forgot to mention, when it shudders, it only last for 1 second or so, not long enough to give it gas and the check engine light does not flash.
    Emry: Thank you, I will check those three things right now, I'll check the part number that I bought and check how both ends are fitting. What about the shim? Do all CPS sensors require the shim on the old part to be reused? I have the old CPS so I could pull it out and compare the lengths of the old and new CPS.
  7. #5
    Jul 2007
    Michigan
    55
    2,061
    Quote Originally Posted by RCinSTP View Post
    No I don't think so. The new one should have its own shim. At least the one I recently bought and installed had one. Anyway, just check those 3 factors and we go from there.
    RCinSTP likes this.
  8. #6
    Aug 2010
    Saint Paul, MN
    311
    The grey harness connection was LOOSE! I'm sure that was the cause of the problem. I'm going to drive the car for awhile and see if the problem is solved. I will reply back in a couple of days, or sooner, if the problem is not solved.
    cchief22 likes this.
  9. #7
    Aug 2010
    Saint Paul, MN
    311
    The loose harness connection did NOT fix the problem. I have the Bentley service manual and I will run through the VAG-COM diagnostic tests specified in the manual, but, I would like to find the specs for the proper depth/length of the Vehicle Speed Sensor, aka Crankshaft Position Sensor to make sure that I have the proper thickness shim. Does anyone know the spec for the sensor? Or, where I can find the specs. I don't see anything in the Bentley manual about replacing the sensor or anything about a shim. I can't find the specs online either.
  10. #8
    Aug 2010
    Saint Paul, MN
    311
    The vag-com showed an intermittent misfire but ~only~ in cylinder 2 so I swapped the spark plugs in cylinders 1 and 2 and that didn't fix it so I replaced the spark plug wire for cylinder 2 and the software went from lots of misfires to ZERO. I drove the car around a bit and it seems like the problem is fixed.
    I think there were several problems. I don't think it was just the plug wire, or the sensors. My guess is that it was the plug wire, plus either the MAF sensor, or the Vehicle Speed Sensor (VSS) aka Crankshaft Position Sensor (CPS).
    Thanks for the help.
  11. #9
    Jul 2007
    Michigan
    55
    2,061
    I suppose you meant the coil wire by sparkplug wire. But yes the coil pack surely can cause misfires and shudder. Glad your problem is fixed.
  12. #10
    Aug 2010
    Saint Paul, MN
    311
    It was the wire going from the coil to the spark plug.
  13. Remove Advertisements
There are currently 2 users browsing this thread. (1 members and 1 guests)
  1. RCinSTP
Similar Threads
  1. I didn't stop on "STOP ENGINE OIL PRESSURE" light. Big Mistake.
    By dannygarces in forum Volkswagen Passat B5 Discussion
    Last Post: 05-05-2014, 02:13 PM
  2. Car shudders when stopped and AC/Heat is on
    By 2001PWowner in forum B5 Garage
    Last Post: 12-20-2006, 09:58 AM
  3. Car telling girlfriend STOP STOP STOP on the road. Help?
    By Mikey's Satty in forum Volkswagen Passat B5 Discussion
    Last Post: 03-09-2006, 04:26 PM
  4. Car shudders when braking between 40-35 mph.
    By GroceryGetter in forum B5 Garage
    Last Post: 11-10-2005, 10:21 AM
