ECM swap
Results 1 to 8 of 8
Thread: ECM swap
    Neutral Maqcro's Avatar
    Apr 2019
    30
    ECM swap
    I’ve got an 01 B5.5 1.8t engine code AWM
    Wondering if the ECM unit can be swapped without any programming needed.
    Thanks.
    2nd Gear
    Jun 2012
    Colorado
    805
    If you have immo3 you will need the PIN from both ECM's. I'm not sure about programming but there is probably some settings for transmission type etc, that might need to be updated in case they are wrong.
    Immobilizer III ECU Swapping - Ross-Tech Wiki
    Apr 2019
    30
    I guess it’s time to see if I can get Ross tech thing I ordered to work. 😩
  5. Remove Advertisements
  6. #4
    Apr 2019
    30
    How can I get the pin for my car? I was able to setup VCDS and can communicate with the car using my laptop but I have no idea what I’m doing.
  7. #5
    May 2006
    Abingdon, MD
    41
    23,136
    Trying to by a performance flashed ECU perhaps? Ian at Reflect Tuning may be able to help you if you need immo removed. Home - Reflect Tuning - Performance Software Great guy and good ECU tunes, btw. I had one of his tunes for my AEB some years ago.
    Glutton for Punishment: 16 A4 S-line Sport pkg Prem+, 04 Passat 1.8T GLS Variant Manual swapped, 2017 Q5 Prem+
  8. #6
    2nd Gear
    Jun 2012
    Colorado
    805
    I don't know the procedure for getting the PIN with VCDS. Maybe search their site or ask on the forums there. The Xtool VAG401 will easily pull the PIN from your current ECM so I know it's possible, just not sure how to do it with VCDS.
  9. #7
    Apr 2019
    30
    I’m gonna buy the vag401. And give it a try.
  10. #8
    2nd Gear
    Jun 2012
    Colorado
    805
    The user interface is pretty limited and there is no documentation but I've had good luck with mine. You can use Ross-Tech website to understand what you need to do and then do it all with the VAG401.
    BTW, getting the PIN from the ECM in the car is easy, getting it from a donor ECM is harder but can still be done. The problem is the immo will disable the car and then you can't talk to the ECM anymore. There is just a small time window to get access to it after the car starts before the immo turns it off. Good luck!
  11. Remove Advertisements
There are currently 2 users browsing this thread. (1 members and 1 guests)
  1. robincoscob
Similar Threads
  1. ECM Swap on B5.5 1.8T w Immo 3
    By Grey.Owl86 in forum B5 Garage
    Last Post: 04-15-2014, 07:15 AM
  2. HELP Removing ECM
    By pac87 in forum B5 Garage
    Last Post: 04-11-2005, 05:57 PM
  3. UPDATE $1,300 to replace ECM post WARRANTY BREACH
    By Slider in forum Volkswagen Passat B5 Discussion
    Last Post: 10-05-2004, 10:28 AM
  4. WTB: ECM for AEB '98 Passat Tip NEED IT ASAP!!!!!!!
    By krautlvr in forum Classified Archive
    Last Post: 08-20-2004, 05:43 PM
  5. (ECM) Engine Control Module, mine shorted out..What is this?
    By VW2003 in forum Volkswagen Passat B5 Discussion
    Last Post: 08-10-2004, 08:20 PM
