2001 Passat Knock sensor code comes back
Page 1 of 2 12 LastLast
Results 1 to 30 of 42
Like Tree5Likes
Thread: 2001 Passat Knock sensor code comes back
    Neutral Maqcro's Avatar
    Apr 2019
    72
    Hey guys I’m a new vw owner and I’ve been running into this code that keeps coming back.
    I’ve got a 2001 Passat 1.8l AWM automatic
    Here are the codes:
    P0327 - knock sensor 1 circuit low input
    16711 - knock sensor circuit low bank 1 - no indication on display
    16795 - secondary air injection reaction injection system incorrect flow detected - no indication on display
    16808 - bank 1 catalytic converter system not efficient enough - no indication on display
    The car seems to idle just fine but has really bad acceleration. Pedal to the floor and it barely wants to speed up at all.
    I’m assuming the knock sensor is preventing engine damage sense it can’t read a proper signal?
    I’ve already tried replacing the bank 1 sensor ( the green one ) torqued it to 15 ft/lbs and nothing changed. Still bad acceleration and code came back.
    Did I torque it wrong? Bad connector on wiring harness? Is there a fuse somewhere? What is the proper way to troubleshoot this... also I don’t have a VAGcom thing I’ve been reading about.
    Thanks.
    Jul 2013
    Chagrin Falls,Ohio
    1,179
    were the ohm readings the same on the old one as the one you replaced ? Knock sensor is an "input" to ECM as to timing(retarding and advancing), when it senses "pinging" it results in cam tensioner adjusting accordingly.......so I am told.......how are you retriving codes? If you have laptop consider cable and Ross-Tech lite
    Apr 2019
    72
    I never ohmed out the knock sensors. I scanned for codes using Bosch advanced obd2 scanner. It came up with knock sensor code and I replaced the sensor since it was fairly cheap. I still have the old sensor and I have a fluke multimeter. What pins should I be looking for resistance on and how much? I’m assuming I can only ohm out a knock sensor while the car is running.
    I do have a laptop... what would I need just a usb to obd2 connector and some software for Ross to work?
  5. Remove Advertisements
  6. #4
    Apr 2019
    72
    I’ve ordered a cable to use with my laptop. Should arrive in 3-5 days. In the meantime I can ohm out knock sensors. What about checking for voltage. If the sensor had no power then it wouldn’t be sending a signal?
  7. #5
    Jul 2013
    Chagrin Falls,Ohio
    1,179
    not sure but there are two basic functioning style of sensors some have 3 wires, some 2 wires regardless use new one to compare to old one. , believe the knock sensors have just 2, it sends a very small "signal" to ECM,resistence should be same ,if you can find a "pinout" diagram for the two wires that go to ECM (I will look for one tonight) you can check continuity between ECM plug and the corresponding knock sensor wires for "breaks" ,if indeed it is knock sensor problem I would be more suspect of wiring than sensor
  8. #6
    Jul 2013
    Chagrin Falls,Ohio
    1,179
    it generates its own power using a piezoelectric crystal tuned to the engines frequency
  9. #7
    2nd Gear cuppie's Avatar
    Dec 2015
    Detroit, MI
    658
    Except that a knock sensor isn't powered externally. It's a piezoelectric microphone - vibration causes it to generate voltage. The ECU looks for specific frequencies and amplitudes in that output to detect 'knock.'
    If absolutely no signal is 'heard' after engine start (because there's always some noise), then the sensor is deemed 'faulty.' And, for failsafe measure, no knock sensor input = no ignition advance (which equals "I'm driving a 1980 Rabbit diesel" acceleration. )
    Check the wiring between the knock sensor & ECU.
    cchief22 likes this.
  10. #8
    Apr 2019
    72
    Sure so the ks is just a transducer converting vibration into electrical signal.
    I’ll check the wires from harness to ECM tomorrow morning. ( I work overnights 😵😵 )
    Just checking the ECM is in the box on driver side with the 5 bolts under the cowl to the right of the brake booster? should I be unplugging the battery and then unplugging the harness from the ECM before checking for continuity so I dont potentially damage the ECM?
  11. #9
    Apr 2019
    72
    My sensor has 3 wires labeled 1 2 3
  12. #10
    2nd Gear
    Jun 2012
    Colorado
    842
    I'd guess one wire is a ground shield and the other 2 wires are signal (+ and ground). I'd also guess the resistance of the piezo element would be quite high since it is a voltage driven (or generating) device.
    It probably isn't something that can be tested with a multi-meter but there's nothing to lose by trying.
  13. #11
    Apr 2019
    72
    I’m with you on that. Probably high resistance... 100k+
    Any info always helps. I’ll be working on getting to the ECM tomorrow afternoon.
  14. #12
    Aug 2011
    Westerville, Ohio
    1,037
    Per the Bentley manual:
    The resistance between any two terminals of the knock sensor should be infinity (open circuit). (Measured with wire harness unplugged.)
    The knock sensors have three wires:
    > Pin 1: signal to ECM: white, ECM pin 106 (sensor 1), yellow, ECM pin 107 (sensor 2)
    > Pin 2: common to both sensors, to ECM: brown (sensor 1), green (sensor 2), spliced in harness, ECM pin 99 (brown)
    > Pin 3: shield, black. Spliced in harness to signal ground, connects to ECM pin 108
    You could easily check the wiring for pins 2 & 3 by confirming continuity between the same pin of knock sensor 2.
    I've not heard of many knock sensor problems, so check the harness for damage. The "low input" code could be caused by a ground on the signal wire, or an open circuit (broken pin 1 wire).
  15. #13
    Apr 2019
    72
    So I was able to get into the ECM and measure continuity between the ks connector and ECM connector.
    .3 ohm on pin 106
    .3 ohm on pin 108
    .3 ohm on pin 99
  16. #14
    Apr 2019
    72
    How would I measure between pin 2 and 3? Measure pin 2 between sensor 1 and 2?
  17. #15
    Aug 2011
    Westerville, Ohio
    1,037
    Since you opened the ECM and measured the wire continuity, there's no need to measure between the two sensors. (The Pin 2 wires for both knock sensors are spliced in the harness, likewise Pin 3 wires. Thus you could check the Pin 2 wiring, for example, by checking for continuity between Pin 2 of the two sensor connectors.)
    So, you have continuity for all three wires. That doesn't leave much to check, except to verify there's not a short between Pin 1 and ground (which there shouldn't be).
    This is a puzzling problem.
  18. #16
    Apr 2019
    72
    Yes very confused on this one which is why I’m here looking for guidance from the experts 😁
    How can I check for short in wiring? Check for continuity between pin 1 from ks connector to common ( pin 99 ) on ECM..?
  19. #17
    6th Gear
    Feb 2013
    Bendigo, Australia
    8,937
    With both sensors and the ECU unplugged.
    Measure the resistance between ECM plug pins 106 & 99, 107 & 99, 108 & 99, 106 & 107, 106 & 108, 107 & 108.
    And between ground and 106, 107, 108, and 99.
    All should read infinity (Open circuit)
    If your other measurements were correct and all of these are infinity, it would appear that you have a faulty UCU.
    "So I was able to get into the ECM and measure continuity between the ks connector and ECM connector.
    .3 ohm on pin 106
    .3 ohm on pin 108
    .3 ohm on pin 99"
    I suggest you do this check to the other sensor connector.
    FrescoGreen01.5 likes this.
  20. #18
    Apr 2019
    72
    I’m assuming if I get any continuity between any of these connectors I will have a short in the harness. If all are open (which they should be) I have a bad ECM... I’ll be checking into this sometime tomorrow and will give an update.
  21. #19
    Jul 2013
    Chagrin Falls,Ohio
    1,179
    not to be daft...... I know there is one knock sensor on my 1.8 on block under intake manifold ,where is the other one located?
  22. #20
    Apr 2019
    72
    They are both under the intake manifold. One between cylinders 1 and 2 next to thermostat housing. One between cylinders 3 and 4. Sensor 1 is green sensor 2 is blue and they connect under the coolant reservoir.
  23. #21
    Jul 2013
    Chagrin Falls,Ohio
    1,179
    you da man, thanks!!! makes sense the more I think about it
  24. #22
    Apr 2019
    72
    I’ve tested all points you mentioned and all are open readings. I’m wondering if maybe the connector isn’t seating 100%???
  25. #23
    Apr 2019
    72
    You see how the tab is broken on the green connector.
    Attached Images Attached Images
  26. #24
    Apr 2019
    72
    Bump
  27. #25
    6th Gear
    Feb 2013
    Bendigo, Australia
    8,937
    Have you done the continuity test on the other connector ?
    If there is a bad connection in any of the relevant connectors, that would cause a problem.
    That broken part is to keep the plug seated, if the plug is fully seated, that is not causing a problem.
    If there is no fault in any of the connectors, wiring or sensors, the fault must be in the ECM.
  28. #26
    Apr 2019
    72
    I haven’t checked sensor 2 (blue) but I can do that tomorrow morning.
  29. #27
    Jul 2013
    Chagrin Falls,Ohio
    1,179
    in this thread there is multiple references to the ECU connector "pin outs" out of curiosity and future reference where is this info archived ,here in forum info base,Bentley, or internet site ? , I have a suspect wire (intake temp) and while car is in garage could check
  30. #28
    PZ
    PZ is offline
    Redline
    May 2002
    Grapevine TX. 01 4M
    56
    25,837
    Bentley has it from what I remember. I think there were very small numbers on the either the ECU or plug too.
  31. #29
    Jul 2013
    Chagrin Falls,Ohio
    1,179
    thanks Tex !
  32. #30
    Aug 2011
    Westerville, Ohio
    1,037
    Quote Originally Posted by cchief22 View Post
    in this thread there is multiple references to the ECU connector "pin outs" ...
    The Bentley schematics are the only source I know of, and you have to select the correct schematic for your model year and engine.
    There isn't a specific pin listing for the ECM connector, rather you just have to go through the schematic and find the individual connector pins. But the schematics are organized by device, so finding the wiring for the intake air sensor (or what have you) is pretty easy.
    There a few devices--the Climatronic head unit, for instance--that do have pinout lists in Bentley, but not the ECM. If you went through all the ECM schematics, you'd find that a particular pin is always an input, or an output, or some specialized function. It's likely that all the ECMs are the same circuit board, but with different functionality programmed per the loaded program.
  33. Remove Advertisements
    Similar Threads
    1. Knock Knock Knodk
      By donaldsanderson in forum Volkswagen Passat B5 Discussion
      Last Post: 01-25-2012, 06:04 AM
    2. knock knock, who's there?
      By NEWMAN'SOWN in forum B5 Garage
      Last Post: 10-01-2008, 11:40 AM
    3. Knock Knock..whos there? u tell me :-(
      By Italianxmna89 in forum Volkswagen Passat B5 Discussion
      Last Post: 08-20-2007, 10:54 PM
    4. Knock Knock
      By monkeymrtee in forum Europe
      Last Post: 07-07-2006, 04:55 PM
