'03 Passat GLX 4Motion 2.8l that won't start
Results 1 to 6 of 6
    Oct 2018
    22
    Well guys I'm at my wits end with this no fuel problem. I checked fuse 28 good, Read some where here if you get a blink on your test light at 28 when cranking that means everything upstream good. I had no sign of it trying to run at the pump so I replaced it still no fuel. I 'm trying to get at the relay panel can't figure out what's holding the lower panel under steering column. I got the 2 star bolts on the door side but can't fine anything on the other side I laid under the column I saw a metal strap looking thing on the other side at the bottom but that's it. Afraid to pry on any thing don't want the break the plastic. Should I have 12 volts at the pump on pin 1&4 key on ? Also there is 2 2 pin connectors on the bottom of the pump top plate . Does it make a difference which one goes on witch one. I no fuel gauge working so I'm assuming i have them reversed. HELP PLEASE
    Feb 2019
    Vermont
    78
    there are two more, one on each side of the steering column, you kinda have to look up at a 45 degree angle from the bottom of your front seat.
    I will run and a grab a photo.
    Feb 2019
    Vermont
    78
    This one is on the far right, almost touching the center console.
    Up is to the right in the photo
    This one you should be able to tell by the photo where it is (in the little cut out)
  5. Remove Advertisements
  6. #4
    Oct 2018
    22
    Thx
  7. #5
    6th Gear
    Feb 2013
    Bendigo, Australia
    8,937
    What is the voltage at fuse #28 while cranking ?
  8. #6
    Oct 2018
    22
    Tomvw hello the volts at fuse 28 was 11.6 when cranking.Quick flash then gone. new fuel pump and 11.5 at the pump connector pin 1 &4 pump won't run.
  9. Remove Advertisements
    Similar Threads
    1. starts then stalls - '03 Passat V6 ATQ 2.8L 4Motion
      By Disassemble in forum New Member Introductions
      Last Post: 10-28-2015, 12:54 PM
    2. Noobie needs help with '04 Passat GLX 4Motion that won't start
      By kelauben in forum New Member Introductions
      Last Post: 07-19-2015, 05:09 PM
    3. Replies: 0
      Last Post: 12-05-2014, 09:57 AM
    4. Replies: 10
      Last Post: 12-26-2013, 08:53 PM
    5. Replies: 1
      Last Post: 06-27-2011, 04:41 AM
