Monson power amp turn on connection
Results 1 to 3 of 3
    Nov 2018
    Boulder
    28
    Question Monson power amp turn on connection
    I recently bought a Passat 04 wagon with after market stereo that sounded pretty bad.. The OEM had the Monsoon, because I have the power amp in the rear side compartment.
    I bought a used Kenwood. I already had the Interface (PAC model C2R-VW2) from the old stereo.. I pulled up the C2R-VW2 manual from the web, and they state to hook up the power amp turn from the Head unit to the blue wire on the interface. I only have a blue and white wire on C2R-VW2. I followed the blue/white wire to the pin that goes into car harness. It did not connected to anything. Maybe thats why only the front bottom speakers only worked. The power amp was not by-passed. Does anybody know what wire is for turning on the power amp? I looked on the web and in these forms with no luck.
    Thanks Eric
    Quick reply to this message Reply
    May 2006
    Abingdon, MD
    41
    23,138
    The turn on is mentioned is from the head unit to interface, not interface to the amp. The Monsoon does not have a turn on wire. If the amp is not on, you would have no sound at all.
    Glutton for Punishment: 16 A4 S-line Sport pkg Prem+, 04 Passat 1.8T GLS Variant Manual swapped, 2017 Q5 Prem+
    2nd Gear cuppie's Avatar
    Dec 2015
    Detroit, MI
    637
    The left-front channel input. There isn't a 'turn-on lead' - it's signal-sensing.
    Assuming that the speakers are still wired to the amp (not to the head unit).... dead tweeters are a possibility, as is broken wiring (typically in the area of the flexy conduit from door to body.)
  5. Remove Advertisements
Similar Threads
  1. New high pressure power steering connection rubber part soaked in fluid?
    By vicktor_1 in forum Volkswagen Passat B5 Discussion
    Last Post: 03-19-2012, 08:57 AM
  2. B5 moonsoon single din to b6 monson double din
    By SHOOTER7 in forum Mobile Electronics
    Last Post: 10-28-2010, 09:49 AM
  3. How to tap radio power connection?
    By the_dread in forum Volkswagen Passat B5 Discussion
    Last Post: 01-01-2008, 07:47 AM
  4. AUX in to monson
    By crash893 in forum Mobile Electronics
    Last Post: 01-10-2005, 07:26 PM
  5. Cruise control and power windows (any connection?)
    By nordicgls in forum Volkswagen Passat B5 Discussion
    Last Post: 11-12-2004, 08:15 AM
