Broken Breather Tube
Results 1 to 8 of 8
Like Tree8Likes
  • 2 Post By VAGguy
  • 5 Post By cuppie
  • 1 Post By AzizLight
Thread: Broken Breather Tube
    TPW
    TPW is offline
    Sep 2016
    Minnesota
    20
    What would cause this tube to keep breaking? I have replaced three times. Does anyone make a metal version of this (06A103213F)?
    3rd Gear axenstar's Avatar
    Mar 2011
    CharlestonSC/Atlanta
    1,675
    Quote Originally Posted by TPW View Post
    I do have original VW used in good condition with metal sleeve. Let me know if you need it.
    Feb 2019
    Vermont
    85
  5. Remove Advertisements
  6. #4
    TPW
    TPW is offline
    Sep 2016
    Minnesota
    20
    Do those sleeves go all the way through end to end? Mine are breaking right above the metal where the clip holds it into the engine.
  7. #5
    May 2006
    Abingdon, MD
    41
    23,140
    That is unfortunately a normal breakage point and no, they don't make a solid metal one nor one that has a metal sleeve end to end. Is everything connected to it secured like it was factory installed? There could be something connected to it that is putting constant pressure on it at a certain angle...
    benzivr6 and John_E like this.
    Glutton for Punishment: 16 A4 S-line Sport pkg Prem+, 04 Passat 1.8T GLS Variant Manual swapped, 2017 Q5 Prem+
  8. #6
    2nd Gear cuppie's Avatar
    Dec 2015
    Detroit, MI
    641
    Could always upfit the thing with an 034 Motorsport PCV kit.
    Can't break plastic parts, if it doesn't have plastic parts anymore.....
    benzivr6, PZ, cchief22 and 2 others like this.
  9. #7
    Jun 2007
    Chicago, IL USA
    13
    I will assume that you have a 1.8t year 2001-
    Check the long metal tube that travels from the rubber TEE and goes up to the valve cover and is bolted to the rear of the cyl head. If it is putting a strain on that tube that might cause your breakage problem.
    You can test the next one by not clamping down on the rubber TEE to see if something comes off. BTW does the rubber TEE attach to the breather tube straight and easy?
    Good Luck!
  10. #8
    Apr 2018
    NYC
    7
    When I replaced mine, I had to take off a retaining clip (basically shaped like a U) off before I could remove breather. I assume you replaced the retaining clip in the proper place when you installed the new part?
    John_E likes this.
  11. Remove Advertisements
    Similar Threads
    1. Replies: 6
      Last Post: 01-20-2015, 04:24 PM
    2. plugged and broken crankcase breather tube need tips
      By arim in forum Volkswagen Passat B5 Discussion
      Last Post: 07-17-2013, 06:37 PM
    3. looking at the PCV Breather Tube 2002 vs 2003 Passat
      By incubus474 in forum Volkswagen Passat B5 Discussion
      Last Post: 06-28-2007, 12:16 PM
    4. Replies: 1
      Last Post: 12-13-2005, 05:37 AM
    5. PCV Breather Tube Replacement or Repair.
      By John22 in forum B5 Garage
      Last Post: 09-29-2005, 04:30 AM
