Aftermarket External Transmission Cooler Recommendations?
Results 1 to 8 of 8
Like Tree3Likes
  • 1 Post By PZ
  • 1 Post By cchief22
Thread: Aftermarket External Transmission Cooler Recommendations?
    3rd Gear axenstar's Avatar
    Mar 2011
    CharlestonSC/Atlanta
    1,676
    Hi everyone,
    Although, I replaced the o rings on the transmission cooling lines at the radiator connection, a bit of fluid is still leaking. I believe it is the radiator side that has the problem. So, I decided to install an external transmission cooler, bypassing the radiator.
    Does anyone have recommendations as far as the brand and fitment ? I am not sure if the universal coolers are any good.
    Jul 2013
    Chagrin Falls,Ohio
    1,077
    sorry,what year is the car ? I did not think it uses o-rings
    Jul 2013
    Chagrin Falls,Ohio
    1,077
    looking up laying on floor, are you talking about these two lines?IMG_20180726_202219.jpgIMG_20180726_202219.jpg
  5. Remove Advertisements
  6. #4
    Mar 2011
    1,676
    Quote Originally Posted by cchief22 View Post
    Hi Chief,
    Thank you. It’s 2003, 1.8t, AWM, automatic.
    I am attaching the picture and the link.
    I replaced the seals in those pipes that go into the radiator.
    https://www.fcpeuro.com/products/aud...uine-n90666003
  7. #5
    PZ
    PZ is offline
    Redline
    May 2002
    Grapevine TX. 01 4M
    55
    25,726
    I would 1st pull the line that is leaking and check the O-ring. It's easy to nick when installing. I would also clean the radiator ports and try again with new seals. As far as aftermarket, ideally a thermostatic cooler would be best, but also the most expensive and complicated. A simple generic straight through design is available at most auto parts stores and any online performance store. I added a generic cooler to our Taurus wagon many years ago and it worked great.
    axenstar likes this.
  8. #6
    Mar 2011
    1,676
    Thank you PZ. Replacing the seals was a pita. I think I am going to try the external cooler.
  9. #7
    Jul 2013
    Chagrin Falls,Ohio
    1,077
    just a thought , not much pressure if any so surprised that they leaked, maybe they sent you the wrong size , as they are really a tight squeeze/fit ,I remember really having to pull hard to remove and push hard to get in when I put in new radiator.
  10. #8
    Jul 2013
    Chagrin Falls,Ohio
    1,077
  11. Remove Advertisements
    Similar Threads
    1. AFTERMARKET Engine Oil Cooler recommendations?
      By Michaelgt2 in forum Volkswagen Passat B5 Discussion
      Last Post: 03-23-2012, 12:51 PM
    2. Replies: 0
      Last Post: 03-27-2011, 08:32 AM
    3. external oil cooler question - normal cooler took a dump
      By vwb5t in forum Volkswagen Passat B5 Discussion
      Last Post: 06-15-2008, 06:48 AM
    4. Replies: 2
      Last Post: 08-22-2007, 10:40 PM
    5. FS: External Side Mounted Oil Cooler
      By EuroGLS in forum Classified Archive
      Last Post: 12-02-2005, 06:16 PM
