Belts not turning
Results 1 to 8 of 8
    Apr 2019
    7
    Belts not turning
    1999 Passat 1.8T Manual. Daughter's car threw a serpentine belt and it pinched between pulleys. Now the engine turns over, but only the center bolt on the end of the crank turns. Opened top end of the timing belt cover and belt doesn't move when crank turns. If the crank timing gear key sheared, does that automatically point to a head job? Trying to determine if it is worth moving forward or pitch it.
    Aug 2010
    Sedalia, CO
    246
    It is very, very likely this resulted in at least two bent valves, but not guaranteed. It all depends on the position of all the exhaust valves at the moment that the cams stopped turning. If the valves were all very nearly closed, they'll be okay. If any were open, those will be bent. Maybe a 1 in 100 chance of none bent?
    The bigger problem however, is the broken key on the crankshaft. It's not a separate key, like on a lawnmower or snowblower. It is an integral piece of the machined crankshaft. I think you'd have to replace the whole crankshaft to fix that.
    5th Gear
    Sep 2002
    Fallbrook CA USA
    5,107
    I believe that on the 1.8T, that key is integral with the gear, which is around $30 or so. The crank keyway might have damage though.
  5. Remove Advertisements
  6. #4
    PZ
    PZ is offline
    Redline
    May 2002
    Grapevine TX. 01 4M
    55
    25,726
    It could be several things, but no matter what, I expect valves are bent. If it's oil pressure related, t could be a seized cam that caused the timing belt to sheer off the ribs. A broken CCT can also jam the cam.
  7. #5
    Apr 2019
    7
    After some further work, I found that the crankshaft timing gear key was sheared off. The crankshaft keyway was still intact and crank turns easily. Pictures below. Removed timing belt (Intact and no ribs damaged) and checked the camshaft movement. Looks like it stopped with the marks lined up as in TDC. How hard should it be to move? I put a wrench on the end of it (with the belt removed) and am unable to move it with significant force. Normal? Does this spell head problems as in PZ's post?
  8. #6
    2nd Gear
    Jun 2014
    S. Florida
    932
    It sounds very much like a head job. At this point I would pull the head vs put back together only to confirm. You could try a borescope to see if you can confirm anything that way.
  9. #7
    Apr 2019
    7
    I'm at an impasse here as I have other projects that I really want to get to! I am thinking this car is getting sold for parts or just towed off! Too much else required to make this worth it. Car is not in top shape anyway. I will follow up with final disposition.
  10. #8
    Jun 2007
    Chicago, IL USA
    13
    Well it depends on how much time and money you want to spend on this Passat and what it is worth in running condition in your location. Does your daughter really like her car?
    If the pistons are not damaged too badly you can get away with either a good used head (U-Pull-It $100) or have that one machined $500?
    Parts needed.....crank pulley & bolt using Locktite, cylinder head & gaskets, head bolts & the long tool bits for the bolts, coolant, oil & filter, timing belt, serpentine belt.
    Give yourself at at least two days since you have to pull the front of the car forward for the timing belt and also replace the cylinder head. Lowest cost on parts might be $300.
    Selling it as it sits dead you might get around $500.00 for it and you would not need to address the other issues but you will need another car for your daughter.
    good luck!
  11. Remove Advertisements
    Similar Threads
    1. Fog lights turning on while turning left or right
      By vicktor_1 in forum Volkswagen Passat B5 Discussion
      Last Post: 11-30-2009, 07:07 AM
    2. belts belts and more belts
      By R36Dreams in forum B5 Garage
      Last Post: 03-26-2006, 04:10 AM
    3. urgent car not turning over <-----
      By crash893 in forum B5 Garage
      Last Post: 03-25-2005, 07:06 AM
    4. Cruse control not turning off everytime.
      By A627tPassat in forum Volkswagen Passat B5 Discussion
      Last Post: 06-26-2003, 03:04 PM
    5. Rough and oscillating idle - not throttle body, plugs, belts
      By k2devx in forum Volkswagen Passat B5 Discussion
      Last Post: 05-08-2003, 04:49 PM
