Before the cat
Results 1 to 11 of 11
Thread: Before the cat
    Mar 2019
    8
    Before the cat
    I popped my hood last night after a short drive and I noticed that the component in between the catalytic converter and the engine was glowing red. I am trying to look up information about this but I don't know what it is called. any help? If i can figure out how to add a picture I will do that.
    5th Gear
    Sep 2002
    Fallbrook CA USA
    5,107
    1.8T engine? (Always give some basic information before asking for help). Might be the turbocharger's turbine housing- but it shouldn't glow red hot after a "short drive" unless that was wide-open throttle up a long hill.
    Mar 2019
    8
    Trying to post a picture
  5. Remove Advertisements
  6. #4
    Mar 2019
    8
    yes, the 1.8T. Sorry, crucial details. The short drive was probably 3 miles. a couple of hills but nothing too big. If I could get a picture to post, it has 2 bolts in it going from the top down.
  7. #5
    Jul 2013
    Chagrin Falls,Ohio
    1,077
    it's the turbo all right...........third bolt in back you cannot see, check your coolant level, imo ,turbine is frozen
  8. #6
    Mar 2019
    8
    I can hear the turbine spin up when it is supposed to. Is there a down pipe on this model of Passat or does the turbo go straight to the catalytic converter?
    On a side note, I changed my oil tonight and notice that there was oil in my intercooler hose.
  9. #7
    5th Gear
    Sep 2002
    Fallbrook CA USA
    5,107
    Some oil in the hose is to be expected. The PCV system discharges crankcase vapors into the duct before the turbo, so everything from there to the intake manifold, including the throttle, will get some oil residue.
  10. #8
    PZ
    PZ is offline
    Redline
    May 2002
    Grapevine TX. 01 4M
    55
    25,726
    The turbo goes straight to the cat, then the downpipe. You could have a clogged cat, your car could be running lean, it could be running hot or it could even be a misfire. Does the car have the CEL on?
  11. #9
    Mar 2019
    8
    Nope. no check engine light. I was looking at it last night and there is an air pump hose (Part# 058 133 785 3) that is cracked. I can't tell if it is leading to the turbo or the secondary air intake. Could this be causing an improper mix?
  12. #10
    2nd Gear
    Jan 2007
    NC - 02 1.8T Tip
    812
    That elbow is on the line that runs from the secondary air injection pump to the combi-valve. It it's leaking you could have less air being injected into the exhaust which could throw the mixture off. If the leak is bad enough, exhaust can leak out of those hoses when the SAIP is supposed to be running. That will mean less exhaust will make it to the oxygen sensor which can also throw the mixture.
  13. #11
    Mar 2019
    8
    Well, that could be the source of the random exhaust smell that I get every now and then. It is cracked in 2 different spots. It could also explain why the sound of the SAIP went from an airplane to more of a whistle. I ordered the $7 part off Amazon and splurged for the $4 overnight shipping. stay tuned.
  14. Remove Advertisements
    Similar Threads
    1. What kind tools to remove nut bolts off cat before turbo?
      By 91NCTDI in forum Volkswagen Passat B5 Discussion
      Last Post: 04-24-2012, 06:47 AM
    2. Random Cat - before/after dyno charts
      By Rusty in forum Volkswagen Passat B5 Discussion
      Last Post: 01-11-2006, 12:51 PM
    3. Removing Cat? (anyone do it before?)
      By Digital in forum Volkswagen Passat B5 Discussion
      Last Post: 11-05-2003, 12:01 PM
    4. 99 audi a4 cat : 99 b5 passat cat
      By JEM in forum Volkswagen Passat B5 Discussion
      Last Post: 02-17-2003, 11:41 AM
