Where exactly is the PCV valve located in a 2002 1.8T AWM? Specifically!
Page 1 of 3 123 LastLast
Results 1 to 30 of 74
Like Tree24Likes
Thread: Where exactly is the PCV valve located in a 2002 1.8T AWM? Specifically!
    Jul 2007
    Michigan
    55
    2,061
    I have watched many videos on YouTube and read many posts on this forum and vortex. No matter what, I am simply not able to locate the PCV valve. This is so darn frustrating to me.
    Could someone very specifically mention where exactly the PCV valve sits in a AWM engine (1.8T 2002 B5.5).
    Thanks.
    Aug 2011
    Westerville, Ohio
    1,017
    Locate the intake casting. It's one piece, then branches off in to four parts, one per cylinder.
    The PCV valve is around 4 inches below the rear-most branch. It essentially hangs in the air--one end is in a tee, the other end connects to the hose that connects to the rear of the cam cover.
    John_E likes this.
    Jul 2007
    Michigan
    55
    2,061
    Quote Originally Posted by FrescoGreen01.5 View Post
    I tried to see it but couldn't. How do you access it if it's below the rear-most branch?
  5. Remove Advertisements
  6. #4
    Aug 2011
    Westerville, Ohio
    1,017
    Lift the coolant tank (unplug electrical connector, leave hoses connected, as you probably know). If your hands aren't too big you can get to it, but beware of other brittle stuff down there (e.g. vacuum lines).
    I changed my PCV and the associated hoses without removing the intake, but it was a chore. Biggest caution: frontwards of the tee where PCV valve connects is an elbow down to the engine. That piece will be very brittle, and the pieces want to fall in to the engine (!). It's held in with a very reluctant clip. Don't remove it if you don't have to.
    I installed an 034 Motorsport silicone hose & billet aluminum PCV kit, which replaced all the above parts, so I undid all the PCV valve clamps after it was out of the car. But then I spent the next two hours fighting with the above mentioned elbow and picking parts of it out of the engine (and praying I didn't miss any).
    cchief22 and Emry like this.
  7. #5
    Jul 2007
    Michigan
    55
    2,061
    Lift the coolant tank (unplug electrical connector, leave hoses connected, as you probably know). If your hands aren't too big you can get to it, but beware of other brittle stuff down there (e.g. vacuum lines). I changed my PCV and the associated hoses without removing the intake, but it was a chore. Biggest caution: frontwards of the tee where PCV valve connects is an elbow down to the engine. That piece will be very brittle, and the pieces want to fall in to the engine (!). It's held in with a very reluctant clip. Don't remove it if you don't have to.
    The way you describe it seems to me a crappy job to do (as usual! ). I only have the valve but now I get scared that may be the attached T or hoses get ripped during removal. So I don't know if I should order those as well. The valve is factory original and never was replaced. The engine suffers serious lack of power and I'm thinking may be that's because of a defective PCV valve. So I decided to replace it after 18 years but didn't know what kind of ordeal I might deal with. So far a kudo for the German engineering
  8. #6
    Jul 2013
    Chagrin Falls,Ohio
    1,057
    there are two "PCV" valves by name(will explain later as cramped for time) ,but the one you are looking for is a Positive Crankcase Ventilation valve, it is located as previously described under the rear most intake manifold runner and to the rear of the oil filter housing, it is inserted "flush" to the two hoses connected to it (vertical orientation) it will be hard to see as only the middle of it can be seen, about 1/4" of it. The failure usually is not so much in the hoses (they do split) but there is a plastic (metal interior reenforced) elbow that is "clipped" to the block that from your maintenance description has probably cracked or went south completely, they are inexpensive to replace while you are there ,care needs to be taken to not let the crap get into your oil pan, difficulty of job I give an honest 2 just because of limited access. as a reference and of the check valves ( the PCV valve is just a big one) all free flow should go towards intake manifold or engine
    Emry likes this.
  9. #7
    Jul 2007
    Michigan
    55
    2,061
    Quote Originally Posted by cchief22 View Post
    Thanks Chief. So you're saying that I need to buy the elbow (S-shaped) hose too? I think based on your description that it is wise to do so because if I start with this and that hose cracks then everything will be ruined. I should take no risk here. (P.S. what's the part number for that?)
  10. #8
    5th Gear
    Oct 2004
    Encinitas CA
    5,358
    My younger son and I did mine (2001 AUG 1.8T) several months ago. We left the intake manifold intact, but the job was a bit challenging. I had started the job earlier and quickly concluded that I should abort, buy new elbow and T fittings, and then not have to worry about damaging the old ones. I bought the whole kit and confirmed that being able to destroy the old hoses and plastic fittings made the job go much faster.
    Emry likes this.
  11. #9
    Jul 2007
    Michigan
    55
    2,061
    Quote Originally Posted by John_E View Post
    Yes I have to the conclusion that it's the best way to do this. It costs a bit more but it's more secure. I'm going to order the hoses and wait a couple of weeks so the weather is a bit warmer. It's no fun to work on the car in open air in this cold condition.
  12. #10
    Jul 2007
    Michigan
    55
    2,061
    Chief you need to clean some of the PMs. I couldn't send you one:
    cchief22 likes this.
  13. #11
    May 2006
    Abingdon, MD
    41
    23,136
    I've done the "PCV" a few times. The proper name for that valve is the "bleeder valve". Bad valve symptoms are usually misfires due to a vac leak or loss of boost pressure. The stopper in the bleeder valve (one-way valve) can become off center and allow air through when boost rises under a load.
    #6 or 6a depending on the year. 2003+ got 6A
    You'll want to replace #2, #5, #10 and of course, the bleeder valve at least. That L-shaped tube at the far right that leads up to the back of the valve cover is metal. Just run some cleaner and a brush through it.
    It's not a hard job if you have EVERYTHING on hand. Don't plan on trying to save any of it. Not worth it. Cleanest way ids to remove it all, including the metal tube and install the 034 kit. The metal tube can be a PAIN to remove. It is bolted to the firewall and has a couple of wires clipped to it.
    Emry likes this.
    Glutton for Punishment: 16 A4 S-line Sport pkg Prem+, 04 Passat 1.8T GLS Variant Manual swapped, 2017 Q5 Prem+
  14. #12
    Jul 2007
    Michigan
    55
    2,061
    Quote Originally Posted by VAGguy View Post
    I certainly do have the loss of boost pressure. The engine struggles especially when it's cold.
    What are the names (part numbers) for #2 and #10. I already have the bleeder valve. So need to order the other two hoses only.
    Yes I can clean up the inside of it with some cleaner.
    I have noticed it. But what is actually easy on these cars?
  15. #13
    May 2006
    Abingdon, MD
    41
    23,136
    I wouldn’t remove the metal tube unless you are replacing it all with the 034 kit. Leave it in place if just cleaning.
  16. #14
    Jul 2007
    Michigan
    55
    2,061
    I'm planning to just replace the bleeder valve and the other two T and hose.
  17. #15
    May 2006
    Abingdon, MD
    41
    23,136
    Here ya go with part numbers. I know I have a new "T" hose (5), upper Y hose at the valve cover (13) and possibly even the Bleeder valve (6A) laying around I can make you a deal on. Whatever you do, DO NOT buy an aftermarket breather tube #2. They just don't fit right into the metal bracket or at all. I bought all that before deciding on just getting the 034 kit after effing around with an aftermarket #2 breather tube.
    2) 06A 103 213 F breather tube
    5) 06A 103 247 valve housing
    6A) 06B 103 245 bleeder valve
    13) 06B 103 221 F breather hose
    cchief22 and bigeyejim like this.
  18. #16
    Jul 2007
    Michigan
    55
    2,061
    Thanks for the part numbers. I already have the bleeder valve (6A). I have also recently removed and cleaned the Y hose (#13). So I'm in need of the T hose and #10 hose (I say #10 per your earlier post).
  19. #17
    2nd Gear
    Jan 2007
    NC - 02 1.8T Tip
    810
    Which bleeder valve did you get? 6A is not the correct bleeder valve for a 2002 AWM. You need #6, which is 035 103 245 A . You may also need a suction jet pump (058133753B), it clogs easily.
    Your breather system should look like this instead of the 2003+ image above.
    Also, I would go ahead and remove the intake manifold, It's not hard at all. Makes everything so much easier.
    Emry likes this.
  20. #18
    Jul 2007
    Michigan
    55
    2,061
    Quote Originally Posted by woodardhsd View Post
    This is what I have:
  21. #19
    May 2006
    Abingdon, MD
    41
    23,136
    Woodward is correct. I didn't have the early AWM/AUG breather pic to attach. Even if you got a 6A by mistake, you can always just put a vacuum cap on the side port of it.
    You don't really need #10 hose up to the intake manifold if it's not torn or abraded. The SJP is a good idea if you've never replaced it. Just waiting for mine to split or clog @172k
    I don't know why my pics are so tiny when they upload.....
  22. #20
    2nd Gear
    Jan 2007
    NC - 02 1.8T Tip
    810
    That's the right one.
    The one in the above diagrams (for the late AWM's) looks like this:
    Here is a better diagram. It says AUG, but it's the same as the early AWM's
  23. #21
    Jul 2007
    Michigan
    55
    2,061
    After watching a few videos, I think I'm comfortable to remove the intake manifold. This way, I will have plenty of room to chnage these suckers and not breaking (hopefully!) anything. This will also let me to take the fuel injectors out and clean them (for the first time after 18 years!).
    I recall a few years back I did replace a 3-way valve. I think that was SJP if I'm not mistaken.
    That's because the pixel sizes of your pics are too big. Open them in "Paint"and resize them by percentage. For instance, open the pic and resize it to the 20% of its original size. Save and upload. That should correct the issue.
    VAGguy likes this.
  24. #22
    Jul 2007
    Michigan
    55
    2,061
    After you mentioned it , I watched a few video and I think it's not that hard and doable. Do I have to buy new clips and o-rings for the fuel injectors? I plan to clean the injectors when I remove the intake.
  25. #23
    2nd Gear
    Jan 2007
    NC - 02 1.8T Tip
    810
    No to new clips, unless they are damaged. I would go ahead and replace the o-rings. Especially is you have oil/fuel around your injectors like this guy: https://www.passatworld.com/forums/v...what-make.html
  26. #24
    Jul 2007
    Michigan
    55
    2,061
    Can I get this from AutoZone or need to go to the stealership? Do you have the part number by any chance?
  27. #25
    2nd Gear
    Jan 2007
    NC - 02 1.8T Tip
    810
    I used this kit from Auto Zone. https://www.autozone.com/fuel-delive...80396_602581_0 Looks like this is an option as well: https://www.autozone.com/fuel-delive...6_196917_11241
  28. #26
    May 2006
    Abingdon, MD
    41
    23,136
    I like that second kit. Includes all 8 o-rings and looks to be some assembly lube as well.
    Oh, I found the pics of what a Bleeder valve looks like when it fails.
    Attached Images Attached Images
  29. #27
    Jul 2007
    Michigan
    55
    2,061
    There are 8 o-rings? I thought only 4. Need to look more carefully because I was about to go to Autozone and buy 4.
  30. #28
    May 2006
    Abingdon, MD
    41
    23,136
    There is an O-ring at both ends of the injector. If just pulling the rail in one piece, then you just need the bottom ones for the manifold. At least you’d have the rest if something went wrong or you decide to do the o-rings at the fuel rail end of the injector.
    Emry likes this.
  31. #29
    Jul 2007
    Michigan
    55
    2,061
    Good point! Actually I want to to completely take out the injectors and clean them througly. They've been sitting there for 18 years now and I'm sure they need a major clean up. No wonder engine doesn't have any power. So, I'll get the 8 ring packet from Autozone because that's the cheapest I found. Even on eBay they were more expensive. Yesterday we have a big snow burst. It's freezing so I need to wait a few days to get a better weather.
  32. #30
    Jul 2007
    Michigan
    55
    2,061
    Cleaned the injectors and replaced their o-rings. Didn't notice much difference in power or fuel economy. But it was a cheap and relatively easy thing to do so I'm not disappointed.
    While at work, believe it or not , after nearly 8 years I finally found the damned bleeder valve. It was too late and rain started so I just quit. But my next move it to attack the valve. I saw two one-time clippers which I'm sure will be tough and frustrating to remove. But, hey, after 18 years on top of her I'm scared of nothing no more.
    Bad News: I'm not sure but I think the oil cooler is leaking. I had cleaned the area underneath of it a few days ago and today I saw a spat of oil there again. If that's true I think I will mourn for 7 days. I don't think changing that gasket would be straight forward.
  33. Remove Advertisements
    Similar Threads
    1. DIY 2002 B5.5 Passat AWM PCV Valve Replace
      By DaOneEnOnly in forum B5 Garage
      Last Post: 04-30-2015, 09:07 PM
    2. PCV Overhaul with new 034motorsport PCV Kit (B5.5 AWM)
      By Matt_1.8T in forum Volkswagen Passat B5 Discussion
      Last Post: 07-23-2014, 12:37 PM
    3. Exactly where is the vacuum tank located in a B5.5?
      By fateshammer in forum Volkswagen Passat B5 Discussion
      Last Post: 10-11-2011, 06:24 PM
    4. where is the PCV located on 1.8t aeb engine!!??
      By rk0030 in forum Volkswagen Passat B5 Discussion
      Last Post: 03-20-2011, 09:27 PM
    5. What's the PCV valve just above the suction valve on the AWM motor?
      By UrbanLegend in forum Volkswagen Passat B5 Discussion
      Last Post: 01-22-2009, 06:56 PM
