Where exactly is the PCV valve located in a 2002 1.8T AWM? Specifically! - Page 2
Page 2 of 2 FirstFirst 12
Results 31 to 51 of 51
Like Tree13Likes
Thread: Where exactly is the PCV valve located in a 2002 1.8T AWM? Specifically!
  1. #31
    May 2006
    Abingdon, MD
    41
    23,113
    It is pretty straight forward to replace that gasket. Plan an oil change around it. remove filter, undo the center nut holding the oil cooler on the filter tube, and shimmy it off. You may or may not need to undo the coolant lines. https://www.passatworld.com/forums/b...placement.html
    Glutton for Punishment: 16 A4 S-line Sport pkg Prem+, 04 Passat 1.8T GLS Variant Manual swapped, 2017 Q5 Prem+
  3. #32
    Jul 2007
    Michigan
    55
    2,008
    Quote Originally Posted by VAGguy View Post
    Yes I noticed it's not difficult. But this center nut is apparently very large (27 mm). I don't have such big socket. First I'll try to remove it with a needle-nose vise. If unsuccessful then I go to HF and but a large socket just for this!
  4. #33
    Jul 2007
    Michigan
    55
    2,008
    Today I discovered that I've never changed the PCV valve in my car. That big 3-way plastic valve it is. May be that's the reason for lack of power. Is there any test to see if the valve is alive? I think I'm gonna order it anyway.
  5. Remove Advertisements
  6. #34
    2nd Gear
    Jan 2007
    NC - 02 1.8T Tip
    808
    Quote Originally Posted by Emry View Post
    Definitely get the socket. The nut is very thin and you'll have a hard time getting it off without messing up something, and a harder time getting it tightened up correctly.
    Which valve is that?
  7. #35
    Jul 2007
    Michigan
    55
    2,008
    Quote Originally Posted by woodardhsd View Post
    OK will get it. We spend so much on keeping these cars alive that one special tool here and there won't make any difference.
    I think they call it suction jet pump. It's a 3-way large and tall plastic valve. I found a complete PCV valve and hoses for $28 on Amazon and ordered it yesterday. I think I'm better off to replace most of these stuff once for all.
  8. #36
    2nd Gear
    Jun 2012
    Colorado
    786
    The suction jet pump isn't the PCV valve but I've used a 'kit' from Amazon that included a few check valves, the SJP, hoses and clamps, etc. The valves look good but I'm less certain about the quality of the hose. Still, it should last long enough and since there is such a mess of connections back there that it is a lot easier to just replace the lot than try to disconnect and replace the SJP by itself.
    Be careful when installing it since there will be lots of brittle plastic bits holding hoses down and other connections that can break if stressed.
  9. #37
    Jul 2007
    Michigan
    55
    2,008
    Quote Originally Posted by Iowegian View Post
    So the mystry still carries on as what exactly is the PCV valve
    With all those one-time clamps out there I think I am gonna have a hard time removing things easily. But as you suggested will be careful as much as needed. Worst case I'll use zip ties if those plastic bits break.
  10. #38
    2nd Gear
    Jan 2007
    NC - 02 1.8T Tip
    808
    I would say the bleeder valve is the closest thing to a traditional PCV valve.
  11. #39
    Jul 2007
    Michigan
    55
    2,008
    These are the PCV kit I bought from Amazon for a $28. I was under impression that the one shown with red arrow is the suction jet pump. But some refer to it as PCV valve. It's so darn confusing.
  12. #40
    PZ
    PZ is offline
    Redline
    May 2002
    Grapevine TX. 01 4M
    55
    25,689
    The little valve on the right of the clamps is the actual Positive Crankcase Ventilation valve. The pancake valve is also part of the PCV system and probably should be changed. Depending on the year, it's either near the back of the valve cover or on the turbo intake hose, to the right of the airbox.
    The suction jet pump uses a venturi effect to increase vacuum to the power brakes. Here is a great writeup on it: https://forums.vwvortex.com/showthre...d-how-it-works
    cchief22 likes this.
  13. #41
    Jul 2007
    Michigan
    55
    2,008
    I'm almost sure SJP is shot because it's been for a long time that my brakes are soft and not as they should be.
    If replacing SJP doesn't correct the lack of power for brakes then I'm thinking to replace the master cylinder which by itself is yet another journey to hell.
  14. #42
    Jul 2007
    Michigan
    55
    2,008
    Went ahead and ordered that one too. Small cost but may make a difference. Shouldn't be hard to replace it.
  15. #43
    2nd Gear
    Jun 2012
    Colorado
    786
    I only replaced the SJP along with the hoses attached to it, basically the pile-o-parts on the left side in your picture.
    If you are planning to replace everything in the picture I'd plan on taking off the air intake and get the gaskets for that as well before starting.
  16. #44
    Jul 2007
    Michigan
    55
    2,008
    Are you referring to intake manifold or something else?
  17. #45
    PZ
    PZ is offline
    Redline
    May 2002
    Grapevine TX. 01 4M
    55
    25,689
    I deleted the SJP on my car when it started leaking, no difference in braking, but the idle was smoother once the vacuum leak was fixed. The engine looks better without the extra hoses.
  18. #46
    2nd Gear
    Jun 2012
    Colorado
    786
    yeah, my bad, I meant the intake manifold.
  19. #47
    2nd Gear
    Jun 2012
    Colorado
    786
    I might do that if/when I get around to installing the 034 PCV kit. Someday....
  20. #48
    Jul 2007
    Michigan
    55
    2,008
    Is there a gasket for that? I tried to remove the manifold when I was cleaning the injectors but very quickly I gave up. Too many hoses are involved.
  21. #49
    Jul 2007
    Michigan
    55
    2,008
    But there is a 3-way check valve connected to SJP that if it goes bad a brake boost failure fault code is generated. I had that and when I replaced that check valve only the fault code went away although my soft brake was not resolved.
  22. #50
    PZ
    PZ is offline
    Redline
    May 2002
    Grapevine TX. 01 4M
    55
    25,689
    That's on later models that have the electric vacuum pump next to the p/s reservoir. Several of the early 1.8T engines did not have a SJP.
  23. #51
    Jul 2007
    Michigan
    55
    2,008
    I have been trying to replace the PCV valves and tubes today. I was able to remove everything except one of clamps attached to the T connector hose. Spent hours and finally got so tried that had to give up for today. Even removed the manifold but still was not able to remove that damn one-time clamp.
    The major issue that the overlap point is behind and I cannot turn it toward me to pry it off.
    Anyone has any creative idea or tip as how I should proceed with this?
  24. Remove Advertisements
There are currently 2 users browsing this thread. (0 members and 2 guests)
    Similar Threads
    1. DIY 2002 B5.5 Passat AWM PCV Valve Replace
      By DaOneEnOnly in forum B5 Garage
      Last Post: 04-30-2015, 09:07 PM
    2. PCV Overhaul with new 034motorsport PCV Kit (B5.5 AWM)
      By Matt_1.8T in forum Volkswagen Passat B5 Discussion
      Last Post: 07-23-2014, 12:37 PM
    3. Exactly where is the vacuum tank located in a B5.5?
      By fateshammer in forum Volkswagen Passat B5 Discussion
      Last Post: 10-11-2011, 06:24 PM
    4. where is the PCV located on 1.8t aeb engine!!??
      By rk0030 in forum Volkswagen Passat B5 Discussion
      Last Post: 03-20-2011, 09:27 PM
    5. What's the PCV valve just above the suction valve on the AWM motor?
      By UrbanLegend in forum Volkswagen Passat B5 Discussion
      Last Post: 01-22-2009, 06:56 PM
