Need ABS control module
Results 1 to 11 of 11
    Neutral 2004 1.8T BBS's Avatar
    May 2012
    Valparaiso, IN
    31
    44
    Yep. Happened to me... ABS module is shot, but when I removed it my wife threw away the module. So, I can't pay to have it sent off and fixed.
    It's a 2004 AWM FWD with M/T and ESP.
    4B0614517G and 0265225124 are the numbers on the hydraulic unit.
    I'll have to call VW and give them my VIN# so I can get the part number for the module if anyone needs it.
    Otherwise, anyone have one?
    Jul 2007
    Michigan
    56
    2,067
    The part at stealership cost you around $1600. It's better to send it off to a repair shop. They charge $100 and the module will work again for a long time. Search the forum and you'll find a few of the repairman who are handy in fixing the ABS module.
    May 2012
    Valparaiso, IN
    31
    44
    Maybe I should've clarified more.
    I don't need the hydraulic unit... Just the module ($640 vs $1600).
    I also don't have the module because my wife threw it away (as stated in original post)
  5. Remove Advertisements
  6. #4
    3rd Gear axenstar's Avatar
    Mar 2011
    CharlestonSC/Atlanta
    1,675
    I replaced my AEB module with a junk yard one for about $30. Works well. I am not sure if you can do that with AWM .
    I would try junkyards.
  7. #5
    Aug 2011
    Westerville, Ohio
    1,020
    I know that CHEAP Bosch 5.3 ABS REPAIR VW Passat Audi A4 A6 A8 S4 (cheapabs.com) also sells refurbished modules. That might be your easiest route. Anything from a junkyard stands a good chance of needing repair, anyway.
    The other difficulty is figuring out exactly which module you need. The ABS modules differ, in coding at least, depending on whether your car is FWD or 4Motion and manual verses Tiptronic. The standard advice would be to get the exact part number off the old module, but, I know... my wife "cleans up" for me, too. There's nothing for it, and for heavens sake don't rub it in! Cheap ABS can probably identify the correct module for you.
    P.S.: Cheap ABS is not a big shop, it's a side job/labor of love. Send an email, wait a day or two. But their work is first class, repair turnaround quick.
    P.P.S.: see the "Vehicles Repaired" pages on cheapabs.com. They list many of the ABS modules with the corresponding pump's part numbers--that's still on your car!
  8. #6
    Mar 2011
    1,675
    That’s what I did. Matched the part numbers and model years.
    If it is defective you can always return it and exchange for another one.
    It’s a $30 solution and worked just fine for me.
    OP, keep the removed unit dust free and in a bag or something till you install.
  9. #7
    2nd Gear
    Jun 2012
    Colorado
    807
    I have an extra one that has been certified to be good by the repair guys (I think it was CheapABS). It is off a 2002 AWM tiptronic 1.8t wagon. If that works for you PM me for details.
    I just re-read your post. Mine is off a tiptronic and I don't know about the ESP or whatever. I'll look for part numbers in the next day or two.
  10. #8
    5th Gear
    Oct 2004
    Encinitas CA
    5,361
    I have a spare you could send in for the standard $100ish resoldering job.
    Make sure you get the right model and part number, however. There are several variants.
  11. #9
    TPW
    TPW is offline
    Sep 2016
    Minnesota
    20
    I have an extra control module for that exact pump from a 2004 Passat. It was working when I removed it. You may need a VAG Com To match it to your vehicle. $40 shipped to IN. If you're interested, send a PM
  12. #10
    Jun 2007
    Chicago, IL USA
    13
    If you have the VCDS tool and had done a full scan when the module was still working, then I think you should have the exact module part # that you need. I went through the VW Catalog (ETKA) yesterday and there seem to be a lot of different modules out there. I am worried that the junkyard module I installed is not perfect for the 2000 Passat. I will probably have the original module, if it even is the original one, repaired. Now the coding on the JY module is identical to the original 0021 but the part number is missing a letter or two at the end. IIRC researching the JY module part # seems to indicate that it is for an Audi A4.
  13. #11
    Sep 2015
    Raleigh, NC
    48
    1,783
    At least you can still drive the care without it. You won't have ABS though. As mentioned. Check with Cheap ABS and put a bag over the exposed pump to keep it clean.
  14. Remove Advertisements
    Similar Threads
    1. ABS Light on. replaced with a fixed abs module but light still on.Need help asap.
      By jujtacoma2010 in forum Volkswagen Passat B5 Discussion
      Last Post: 05-19-2014, 09:12 PM
    2. Need ABS Control Module Repaired 2000 passat Los Angeles area.
      By DNast in forum Volkswagen Passat B5 Discussion
      Last Post: 02-24-2012, 02:08 PM
    3. Need ABS Control Module Repaired 2000 passat Los Angeles area.
      Last Post: 02-24-2012, 03:47 AM
    4. Replies: 12
      Last Post: 04-30-2009, 10:13 PM
    5. Replies: 4
      Last Post: 08-15-2007, 05:36 PM
