Instructions For Building Your Own VAG COM Interface
Page 1 of 5 12345 LastLast
Results 1 to 30 of 134
    4th Gear
    Jan 2003
    Sacramento, CA .... 2001 Audi A6 2.7T
    2,505
    Well guys... I said I was gonna follow up on my quest to make this tool and here it is! IT WORKED!!!
    And I took some photos along the way to share with you guys my little project in case some of you are interested in making one also. It's SUPER EASY... if you have the right tools and patience.
    Kudos to Jeff at Planetfall for sharing this great stuff. Thanks!
    So here it is:
    PLEASE NOTE!! If you do attempt this project, PLEASE PLEASE READ all caution labels on anything that you buy (really it's the ferric chloride.) Take it slow and use safety devices (ie... mask, goggles, gloves, etc.) To give you an idea of what skill level it takes to do this, I'll use me as an example. I'm not an Electrical Engineer. I'm a Computer Programmer with an MBA and a tv broadcast journalism background. I feel that if you can read and follow directions (along with some common sense), you should do just fine and be able to complete this project.
    Now for the disclaimer:
    You will be attempting this project on your own and will accept full liability and responsibility for what ever happens should something go wrong. I take no responsibility for any mishaps that should come up while you work on this project and while you use it to work on your car. Basically, you do this at your own risk.
    So what does this device do? What's its purpose? Why would someone want one of these VAG-COM devices?
    The answer is this: In addition to the tweaks (change your transmission to sport mode, change your auto-door lock, tweak your stereo, etc) that you can do to your car, VAG-COM allows you to read the codes that your car throws in the event something is wrong (ie... your car runs sluggish or Check Engine Light is on, etc.. ). With the code and the bentley (or someone here on the forum can help you) you would be able to pinpoint exactly what's wrong with your car before you even pull into the dealership. If it's a simple fix, you can even do it yourself and save yourself $$ from having it serviced at the dealer (if your car is out of warranty).
    Also... with the pluggins supplied by ROSS-TECH, you can also use VAG-SCOPE to log data about the performance of your engine.
    LEVEL OF PROJECT DIFFICULTY (SCALE OF 1 TO 10 with 10 being the hardest): 4.5
    TIME FOR COMPLETING PROJECT: About 1.0 to 2.0 hours (maybe a little longer) depending on skill level
    COST OF PROJECT: Less than $8.00 if you already have the tools and supplies
    Print out the schematic from Jeff's planetfall.com's website on transparancy. Print out the instructions. All the parts necessary for this project is also at this website.
    Some have been confused about which side goes to which on the schematics. Here's an pic of the layout which I modified to help give reference:
    * Click here for the parts list and schematics
    * Click here for the guide written by Jeff.
    * Click here for the PDF version of the board layout. Print this on transparancy
    PARTS:
    Obtain all the parts necessary for this little project (transistors, copper boards, switches, ferric chloride, etc). If you order from digikey.com, you won't find Part#2N3904-ND (NPN SML SIG G.P. AMP&SWITCH TO92 ) but there is an alternative that you can use that will work (which is what I used!): Part#497-2395-ND (TRANSISTOR NPN 60V 200MA TO-92).
    TOOLS OF THE TRADE:
    - Dremel tool or something similar. I used a cheap $2.99 rotary tool which I got from a long time ago from HarborFreight.com.
    - Soldering Iron ($2.99 from Fry's)
    - Solder (Get the really thin one)
    - Rubber Gloves
    - Handy Helper (Look in the pictures below. It's this metal thing with arms on it). Helps to hold your board while you work ($7.99 from Radioshack). I noticed that Harbor Frieght also sells this same tool for half the price of what I paid for!
    - Fun Hat
    - Digital Multimeter is helpful here to test your leads. Got it for $2.99 from Harborfreight.com
    - Plastic Ziploc Container (!!!NEVER TO BE USED FOR STORING FOOD EVER EVER AGAIN!!!)
    - Nail Polish Remover
    CABLES:
    - Type Cable 7 (Is what connects from the car to this device). This is the most expensive piece. You can build your own or you can buy one from Multiplex Engineering for I think $20 or so.
    - Serial Cable (Is what connects from the device to your computer). This should be relatively cheap, about $5 or so, maybe less depending on where you get it. I got mine from Fry's Electronics.
    SOFTWARE:
    - VAG-COM (Registered version $99 will offer full functionality of the software... or shareware version which allows you to do most things.) Whether which one is right for you (Registered versus Shareware) depends on your needs. If you spend a ton of hours on your car and you do EVERYTHING on your own, then it's best to get the registered version. Now if you only play with your car once in a while and want to simply change a few minor stuff and be able to read codes, then the shareware version will probably meet your needs.
    CLICK HERE TO SEE A COMPARISON BETWEEN THE TWO VERSIONS
    CLICK FOR VAG-COM SOFTWARE DOWNLOAD
    While you're there... I'd recommend downloading the "55 page printable manual version 311.2" and read through it to understand how to use VAG-COM. Very easy read.
    Start with a bare copper-clad board. I bought the copper board from Fry's Electronics for like $2.50 or something like that. It's big enough to make three of these boards. Clean the board well using rubbing alcohol to get rid of any dirt, grease, or any buidup that's on the board. Print out the schematic on a transparancy per the instructions and it looks like the picture below. Under no circumstances should you attemp to enlarge the print or reduce the print since some of the components are true to size, meaning if you enlarge it or shrink the print, your components won't fit later.
    I found it easier to fold the transparancy in half and slide the copper clad
    in between to prep it for ironing.
    Iron the heck out of it for about 5 min - 10 min at about 85% high heat.
    Don't let the transparancy melt though!! I'd recommend making several of these boards in case you mess up since it's really cheap (like pennies). The transparency will get hot... so take care not to burn yourself.
    Let it cool in a sink full of cold water for a few minutes.
    Slowly and carefully peel back the transparancy and you should have your copper clad board with the toner on it!! Most of the toner should be transferred to the board. If not, and there are exposed copper where there shouldn't be, you can simply use a super fine tip permanent pen (available at your local office supply store. get the finest tip you can fine) by sharpee to fix it by drawing on it and connecting the lines. However if there's too much toner missing (It happened to me the 1st time), simply use nail polish remover to remove the toner, print out another artwork, and go iron the print back on again.
    Here's a pic of my dog (Roxie) who was with me in the build process.
    Get a "ZipLock" plastic container (to be used for this AND NEVER USED FOR FOOD EVER AGAIN!!!), pour about a 1/4 cup of ferric chloride (I got from Fry's Electronics) in it. Mix with about 1/4 cup of hot (but not boiling hot) water (Basically a 50/50 mix). (Reason for heat is to speed up the etching process, otherwise it can take hours!!)
    PUT ON A PAIR OF RUBBER GLOVES FOR THIS and use a mask to avoid inhaling the fumes! Better be safe than sorry. Place your copperboard with the artwork on it into the plastic container. Close the lid and agitate the heck out of it for a good 5 min to 10 min or until all the copper is gone. If in the event your mixture has gotten cold and your etching process is taking longer than 10 minutes, have no fear. Do this to get the process going again. Fill your sink with steaming hot water. Place the ziploc container with the ferric chloride and copper board in it in the sink. Agitate. The warm/hot water in the sink will get the ferric chloride going again. Check every 5 mins or so to check the progress of your board.
    Once the last step is done, wash the board thoroughly with cold water to clean it. Keep the cold water facet running for a few minutes when you're done to flush out the ferric chloride. Wash everything well including the gloves, the sink counter, etc.
    Use nail polish remover to remove the toner that's covering what's left of the copper. It should look like the picture below after you're done cleaning. All the copper lines should be there (I would compare your result with the schematic to make sure it's all there). If not, you can either use a copper pen to fix it or just start all over again. If there are copper leads that are fused (and it's not suppose to be), I'd recommend using a sanding drill to sand them apart or simply start all over.
    Here's a comparison of one that has toner on it and one that doesn't.
    I dont' have a picture here of it... but you want to get a dremel tool or
    something similar with a small bit to start drilling tiny little holes on it
    where the components are suppose to be. Don't over do it with the holes. Just make a hole large enough for the leads to fit. If you over do it, you'll drill away the copper plating (which is what the solder sticks to). Without copper plating, the solder won't stick! In the picture below, you can see that I already did the drilling.
    This is where the challenging part is.... soldering. Take your sweet time and do it right. Mistakes are not forgiving since fixing them poses a challenge. Solder sticks very nicely to clean copper. So if you accidentially solder two copper leads together... try and fix it. But if there's just too much damage, start over. Patience is key here.
    Here's progress...
    More progress... almost done...
    Very close...
    And ta da!! All done! Now download the shareware version from Ross-Tech.com (if you don't want to pay $99 for the registered version), load it up, hook the baby up with a Cable 7 and serial cable, and you're set to go!!
    Here are some photos of the connection. My car is an Audi A6 2.7 so the OBDII connector is located on the lower left hand side of the steering column. This is what the connector looks like:
    Now it's connected:
    The full connection:
    A pic of the computer screen which show information about my car:
    ---- Edit with more info ----
    I was able to read all my codes. Plus I was able to recode. First thing I did, recode my transmission to sport mode.
    I'll take some additional photos and post it on here tonight or sometime soon. (ie.. setups, hookups, etc).
    Keep checking back for updates if you're interested!
    2nd Gear
    May 2001
    San Jose, CA
    612
    Greatest Post Ever!
    Apr 2001
    Simi Valley, SoCAL
    1,512
    amazing! This will be a fun project.
    At least, one I bought comes with a cover. :wink:
  5. Remove Advertisements
  6. #4
    May 2003
    Vancouver, BC
    38
    1,815
    That's awesome, I'm so gonna try this when I get some free time in the next few weeks.
    :bow:
  7. #5
    4th Gear
    Nov 2002
    N Lake Co, IL
    2,818
    Awesome dude :bow:
  8. #6
    Mar 2003
    Raleigh NC USA
    55
    Wow! That looks GREAT!!! What would you charge to demo the process again and send me the comleted device??? I am soldering impaired.
    Russ
  9. #7
    20vvillian
    Guest
    am i the only one who knows nothing a diodes and soldering and schematics, im truely amazed! :shock:
  10. #8
    Oct 2003
    Queens,New York
    49
    2,178
    this club is better than NASA...
  11. #9
    4th Gear
    Jul 2003
    East Coast
    4,876
    Those are tears of joy baby!
    This is fantastic. Three cheers for oneguyinCA
  12. #10
    May 2002
    Charleston, SC USA '98 GLS 1.8T
    9,668
    Might as well just spend th $200 for the software and hardware. Im not the best at soldering, and something like that looks like it takes quite a bit of time.
    Thanks for sharing though. Home made stuff always gets me going. :bow:
  13. #11
    4th Gear
    Aug 2002
    Staten Island, NY
    4,705
    Nice work, great write up...now the question is, do I dare attempt this :suspicio:
  14. #12
    4th Gear
    Jul 2003
    East Coast
    4,876
    2N3904-ND NPN SML SIG G.P. AMP&SWITCH TO92 T1 & T2
    Cannot find this part available at Digi-Key. Anyone have any other sources to purchase this electronic?
  15. #13
    4th Gear
    Jan 2003
    Moscow but 011 in th
    54
    4,011
    :bow: :bow: :bow:
    How much will cost in GB? :wink:
  16. #14
    4th Gear
    Jan 2003
    2,505
    The whole project will probably take about 1 hour to complete (It took me about 2 because I was taking it SUPER SLOW and running around finding my tools that I need.
    I have to admit, it's REALLY fun and FAIRLY EASY!! On a scale of 1 to 10 on difficulty with 10 being the hardest, I'd say it's about a 4 or a 5. The savings is there (you can figure out the math). All the parts cost less than $10. Shareware of the software, FREE.
    Salmanilla:
    To demo again and sell it? I thought about it. Probably something like $20 shipped to cover the parts, my time, packaging and shipping. I have one other board left that I haven't started drilling. It's a complete print. Just needs drilling, and assembly. Oh yea... I have all the parts too!
    PassatVariantPunk:
    Yes there is an alternative that you can use that will work (which is what I used!): Part#497-2395-ND from digikey.com. The description is: TRANSISTOR NPN 60V 200MA TO-92
    Nenad:
    Group Buy? Oooo... this one should be real cheap since ordering these components in quantity will GREATLY drive the price down! Now you're talking!
  17. #15
    4th Gear
    Jul 2003
    East Coast
    4,876
    Thanks for the reply. I will get on that part. Order maybe as soon as today. Going to talk to one of me EE professors for some tools and see if he will assist me. Never really soldered before.
    As for the price, still got to pay for the cable too. The cable connecting the tool to your ride is about 20 bucks. Just an FYI.
    I was reading on the ROSS-Tech site, and they have this little write up why you should buy the VAGCOM and not this OBDII stuff.. the OBDII tool didnt recognize any errors on a GTI but the VAGCOM ead 10 faults.
    http://www.ross-tech.com/vag-com/dtc-comparison.html
    True? Any disadvantage from this homemade tool and the VAGCOM in terms of recognizing faults.?
    Thanks ya'll.
    Stephen.
  18. #16
    4th Gear
    Jan 2003
    2,505
    Stephen,
    I was reading the info on the link you provided. VAGCOM and OBDII are both software. VAGCOM I believe is made by Ross-Tech. Then there are other OBDII software that other companies make.
    What Ross-Tech is saying is that THEIR software is able to read fault codes that other OBDII software can't (Go back to the link you provided and notice the screen shots are different between VAG-COM and OBDII generics).
    This homemade VAG-COM tool allows you to connect to the car and make use of the VAG-COM sofware without paying some $70 or $80 for the cable. So being that the home-made tool is using the VAG-COM software from Ross-Tech, I imagine it should operate as advertised (less the registered VAG-COM software).
    Hope that helps!!
    ~Eddie
  19. #17
    2nd Gear
    Sep 2003
    San Diego, CA
    38
    711
    what did you use to cover teh board.. or was it left as is??
  20. #18
    Nov 2002
    Planet Earth
    40
    17,568
    WOW....speachless. Mad props!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!
    Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
  21. #19
    2nd Gear
    Sep 2003
    Fargo, ND
    541
    This design works pretty good. I've scanned at least 20 some cars with it over the last 3 years.
    You can also do it without all the etching. Just use jumper wire instead of etching it all if want. However you'll find the cost of the parts you only save like $20. You still have to buy the software.
  22. #20
    4th Gear
    Jan 2003
    2,505
    Jdubu81:
    It's left as is right now, but I will be looking for a cover for it from Fry's or Radio Shack.
  23. #21
    5th Gear
    Dec 2001
    Exiled in BKNY...
    44
    6,874
    GENIUS.
    Most impressive flesh creature.
  24. #22
    4th Gear
    Jul 2003
    East Coast
    4,876
    Quote Originally Posted by LIVE4SPD
    http://www.ross-tech.com/vag-com/download/
    I remember coming across another software package as well on the net. I found it through Club so perhaps a search could resurrect this.
    Eddie - thank you very much for your quick responses. I am going to order the goodies today through DigiKey.com . I spoke with an EE professor of mine and also with some of the EE Dept's technicians. They agreed to assist me. The technicians informed me to just use perf-board instead of etching. Can't wait - thanks for the information!
  25. #23
    Sep 2002
    Philly, PA - BADDEST PASSAT ON THE BLOCK
    1,926
    I was thinking of doing this. And making extras. Does anyone know if there will be any problems selling these. I don't want to break and laws or take money out of anyones pockets by doing this.
  26. #24
    2nd Gear
    Jun 2000
    Springfield MA USA
    697
    Quote Originally Posted by jeffsu350
    I think you would have to check with Jeff's planetfall.com. The circuit diagram does say copy right on it. I believe he has made it available for individual use, but you using it to produce something you are going to sell may be another issue. I would check with him on that. Other than that I do not see any legal issues. The trick here would be to get Jeff to OK this and then get a place to do a run of 100 boards for you. The rest is just putting parts in baggies and shipping it our for those of us that would want to solder, and you soldering the ones for the folks that dont. If this was a printed board That I could buy for say $10 and another $8 in parts + $20 for cables your looking at only 40% or the purchase price. But sourcing the Ferric Chloride although simple enough is just not something I would want to bother with.
  27. #25
    May 2001
    Alta Loma, CA, USA
    1,638
    nice job! Let us know if you do a group buy on this. I would like to be in on this
  28. #26
    Confused
    Dec 2002
    State of Confusion
    9
    3,564
    yup...me too, it' hit it. lemme know.
  29. #27
    4th Gear
    Jan 2003
    2,505
    Guys... thought the opinions from this thread (cross-threaded) from VWVortex would interest you:
    http://forums.vwvortex.com/zerothread?id=1192509.
    Some people are very critical when people "attempt" this project voluntarily on their own.
  30. #28
    4th Gear
    Jul 2003
    East Coast
    4,876
    In response to VWVortex: they are known to be quick to anger. We here at CB5 are extremely blessed to be able to discuss an automobile admiration in our life in a professional, respectful, and of course goofy manner. CB5 and VWVortex are not synonomous.
    The one firey thread comes from the owner of Ross-Tech, UWE. Being that this business adventure soley revolves about a single hardware product, yes this DIY approach could be seen as threatening. Now wheather this requires one to become angered and ready to lay down some less than kind words is left to one's morals.
    I am sorry to see Eddie getting such flak for his post @ Vortex.. your post is surely welcome at this forum.. especially by an EE in training who happens to have a special place in his heart for a black B5 wagon. Thanks man!
    You did well supporting yourself over there.
    PS I am builing mine now at school. Class is out early today. Using perf board though makes it a bit more difficult. No worries keep bothering the techs here in the office. Eddie, lemme get this straight, the male serial on the VAG's board is the side which attaches to the OBDII cable? Trying to lay this thing out on the perf.
  31. #29
    4th Gear
    Jan 2003
    2,505
    PassatVariantPunk:
    Thanks for the support!
    To answer your question:
    Yes... DB9M (Male) is on the side which connects to the OBDII cable. DB9F (Female) is the side that connects to the computer. Here are the original diagrams for reference:
    Now here's one I put together for easier reading:
  32. #30
    4th Gear
    Jul 2003
    East Coast
    4,876
    Seems like that single opto-coupler chip makes things much more simple. Too bad Digi-Key didn't have it in stock.
    Got a lot of extra parts Guess the part list has so many in case of any soldering mishaps?
    The board is set up.. believe it's properly done. Thursday or so I will have time to solder things up. The cable is in the mail. Assuming my 30 minute crash course in soldering this afternoon serves me well, maybe have some communication with my Wagon come this weekend?
    Any one else out there doing this build?
  33. Remove Advertisements
