FS: Alpine PXA-H701 Multimedia Manager
Results 1 to 11 of 11
    Mar 2006
    Queens, New York
    36
    2,097
    The processor was yoused with alpine w200, and made a gret combo for tuning your sound system. install is very easy.
    • Digital Time Correction
    • Dolby Pro Logic II and DTS® Decoding
    • 31-Band Graphic
    • Stand-alone operation with RUX-C701
    The ultimate way to add multi-channel music with sophisticated digital sound processing to any system. Combine it with an Alpine Ai-NET DVD head unit such as the DVA-9861, for an experience beyond belief, you have to hear it to believe it. The PXA-H701 multimedia manager™ is controllable from IVA-D310, DVA-9965, and DVA-9860. Use it in stand-alone mode with the RUX-C701 controller and achieve perfect imaging with manual or auto time correction. Enjoy multi-channel movie sound with Dolby® Digital and DTS® Digital Surround deocoding. Connect three source components via optical digital inputs. If you want perfectly customized multi-channel sound, this is what you need.
    FEATURES
    • 11-Band Digital Parametric EQ 4 Bands Front, 4 Bands Rear, 2 Bands Center, 1 Band Subwoofer
    • 17 Band Digital Parametric Equalizer
    • 31-Band Graphic Equalizer
    • 4 Volt PreOut
    • 6 PreOuts
    • 6 User Programmable Presets
    • 6/12/18/24/30dB/OFF Selectable Crossover
    • Adjustable Center Delay
    • Ai-NET or RCA Inputs
    • Auto Time Correction
    • Dolby Digital®, Dolby Pro-Logic® and DTS® Decoding
    • Gold Plated RCA Jacks
    • Independently Adjustable Channel Level
    • MDAC Digital to Analog Converter
    • Manual Time Correction
    • MediaXpander™
    • Navaigation Mix Input
    • Rear Mix Capibility
    • S.T.A.R. Circuitry
    • Selectable Listening Modes Standard/Maximum/Late Night
    • Speaker Selection Mode
    Front: Large/Small
    Center: Large/Small/Off
    Rear: Large/Small/Off
    • Subwoofer Level Control
    SPECIFICATIONS
    • Band 1 : 20/ 22/ 25/ 28/ 31.5/ 36/ 40/ 45/ 50/ 56/ 63/ 71/ 80 (Hz)
    • Band 1 : 20/ 22/ 25/ 28/ 31.5/ 40/ 45/ 50/ 56/ 63/ 71/ 80/ 90/ 100/ 110/ 125/ 140/ 160/ 180/ 200/ 220/ 250/ 280/ 315/ 360/ 400/ 450/ 500 (Hz)
    • Band 2 : 50/ 56/ 63/ 71/ 80/ 90/ 100/ 110/ 125/ 140/ 160/ 180/ 200 (Hz)
    • Band 2 : 50/ 56/ 63/ 71/ 80/ 90/ 100/ 110/ 125/ 140/ 160/ 180/ 200/ 220/ 250/ 280/ 315/ 360/ 400/ 450/ 500/ 560/ 630/ 710/ 800/ 900/ 1k/ 1.1k/ 1.2k (Hz)
    • Band 3 : 125/ 140/ 160/ 180/ 200/ 220/ 250/ 280/ 315/ 360/ 400/ 450/ 500/ 560/ 630/ 710/ 800/ 900/ 1k/ 1.1k/ 1.2k/ 1.4k/ 1.6k/ 1.8k/ 2k/ 2.2k/ 2.5k/ 2.8k/ 3.2k (Hz)
    • Band 4 : 315/ 360/ 400/ 450/ 500/ 560/ 630/ 710/ 800/ 900/ 1k/ 1.1k/ 1.2k/ 1.4k/ 1.6k/ 1.8k/ 2k/ 2.2k/ 2.5k/ 2.8k/ 3.2k/ 3.6k/ 4k/ 4.5k/ 5k/ 5.6k/ 6.3k/ 7.1k/ 8k (Hz)
    • Band 5 : 800/ 900/ 1k/ 1.1k/ 1.2k/ 1.4k/ 1.6k/ 1.8k/ 2k/ 2.2k/ 2.5k/ 2.8k/ 3.2k/ 3.6k/ 4k/ 4.5k/ 5k/ 5.6k/ 6.3k/ 7.1k/ 8k/ 9k/ 10k/ 11k/ 12.5k/ 14k/ 16k/ 18k/ 20k (Hz)
    • Channel Seperation : 80 dB
    • Controller Size (WxHxD)in : 6-3/4" x 1-13/16" x 1"
    • Controller Size (WxHxD)mm : 170mm x 46mm x 25.7mm
    • Controller Weight : 159 g (5 oz.)
    • DAC resolution : MDAC (Multi-level DAC) 26kHz /24dB
    • Frequency Response : 20Hz-20kHz (±1dB)
    • Input Impedance : Greater Than10k ohms
    • Input Sensitivity : 850mA (2V for analog 1 only)
    • Main Chassis Size (WxHxD)in : 10-3/16" x 1-9/16" x 6-1/4"
    • Main Chassis Size (WxHxD)mm : 260mm x 40mm x 160mm
    • Main Chassis Weight : 1.1Kg (2lbs. 6 oz.)
    • Number of Bands : 17 bands (5 Front, 5 Rear, 5 Center, 2 Subwoofer)
    • Number of D/A Converters : 8
    • Number of Presets : 6 (User Selectable)
    • Number of outputs : 8 (2 Front1 L/R, 2 Front2 L/R, 2 Rear1 L/R, 1 Center, 1 Subwoofer)
    • Output Impedance : Less Than 1k ohms
    • Output Voltage : 4V (with 10 k ohms load)
    • Parametric Eq "Q" Factor : 0.5/1.0/2.0/3.0/4.0/5.0
    • Parametric Eq Boost/Cut Range : ±9dB in steps of 1dB
    • Power Requirement : 11-16V DC (negative ground)
    • Signal to Noise Ratio : 110 dB (Digital Optical In)
    • Subwoofer Crossover Frequency : 20 - 200Hz (1/6 Octave steps)
    • Subwoofer Crossover Slope : 6/12/18/24/30dB
    • Subwoofer Level Control : 0 to +15dB
    • Time Correction Control Range : 0-20ms (0.1ms steps)
    • Total Harmonic Distortion : 0.02%(at 1kHz)
    price : $300 shiped
    Quick reply to this message Reply
    Mar 2006
    Queens, New York
    36
    2,097
    great for tuning your sound system
    Mar 2006
    Queens, New York
    36
    2,097
    will go on ebay if there will be no takers...
  5. Remove Advertisements
  6. #4
    Mar 2006
    Queens, New York
    36
    2,097
    ttt
  7. #5
    Redline
    May 2003
    Dyess AFB, Texas
    44
    23,183
    i might want this.
  8. #6
    Mar 2006
    Queens, New York
    36
    2,097
    Quote Originally Posted by quality_sound View Post
    i might want this.
    still have it so just let me know.
  9. #7
    Mar 2006
    Queens, New York
    36
    2,097
    ttt
  10. #8
    Mar 2006
    Queens, New York
    36
    2,097
    ttt
  11. #9
    Mar 2006
    Queens, New York
    36
    2,097
    bump
  12. #10
    Mar 2006
    Queens, New York
    36
    2,097
    price drop 275 shiped
  13. #11
    Mar 2006
    Queens, New York
    36
    2,097
    ttt
  14. Remove Advertisements
