K04 - All you need to know guide
Page 1 of 2 12 LastLast
Results 1 to 30 of 34
    Nov 2002
    Planet Earth
    40
    17,568
    Questions about Turbo kits keep coming, and since I have couple of years of experience with this unit I thought it would be a good idea to create a little write up (as I haven't done one in years).
    NOTE: Keep in mind that this thread is related to B5s only. We still really haven't gotten to the bottom of the whole K03 Sport thing with B5.5, even though people have put out little more power with them then K04......but they were also heavily modded and there is no direct Dyno #s without the heavy mods (that I know off anyways). So B5.5 guys "take it how you want it"
    If you have any suggestions or find any mistakes in my write up please PM me and let me know, TIA.
    There is many factors and things to consider when purchasing K04 turbo and IMO it's a great idea to know as much as possible before buying it (goes for anything). Hopefully this will make your decision easier.
    Spec/info:
    K04-015 Turbocharger is a direct swap. Exhaust Manifold/connections/brackets/Cat bolts are all similar and fit exactly like the K03 unit. The difference is mostly in the wheel. Also from the info I gathered housing is a little bigger, although it is not noticeable by eye unless you wip out some calipers. Bottom line K04 flows more air then K03 and you can gain about 30-40hp over chipped K03.
    Here are some pictures of the K03 and K04 side by side:
    http://www.audiworld.com/news/99/turbo/lo4lko4r1.jpg
    http://www.audiworld.com/news/99/turbo/ko3lko4r2.jpg
    When purchasing these units make sure you have a blue tag on it and it says k04-015. When I first received my turbo it didn't have this tag.....it was red, and after a week of research I found out that it wasn't a REAL K04 but a Eurospec model, of course I returned it right away. HermanH and some vortex members have mixed reviews of the Eurospec turbo's, something to keep in mind and to look out for. Keep in mind that problems these folks have might not be related to the turbo itself. Basically I don't like to be the guinea pig so a real K04 was a must.
    Performance:
    You can expect about 230hp and 260ft lbs of torque out of K04 set up. It all depends on # of modifications you do. Some end up with more power, some with less. Expect your Passat to be a solid low 15/mid 14s car (on a good day, and with a good driver) in a 1/4 mile. Most people that achieved low 14s are mostly A4 owners, as AWD does wonders to 60 foot times. From a roll you will get a performance of your average low 14s car (S2000, WRX, Mustang GT, 350Z etc <<<all stock of course). You read some of my "K04 stories" and as anything keep in mind that there is just SO many circumstances (driver, conditions, your and other car's conditions, tires.....I can go on and on). Also I'm only talking straight line acceleration performance.
    Torque steer is none existent thanks to equal length half shafts, but putting even 230hp to the ground can be a challenge. Good set of tires only solves part of that problem. Other then that we all know the limits of FWD. Personally I wouldn't want ANYTHING over 230-250hp on ANY FWD car.IMO just doesn't make sense, especially if you consider the money you are spending.
    So, if you are looking for serious performance K04 is NOT the way to go. It is simply a cheap upgrade to give your car that extra power over the chip or "chipping your car all over again" as some say and I agree. Most noticeable difference is in the upper RPM range, where K03 runs out of breath is where K04 shines.
    IMO to take this car and make it a true monster would cost arm and a leg.....and it would still not be on par with most RWD or AWD sport cars/sedans
    Personally I think K04 is a perfect upgrade for Passat. It makes it into a car I wanted when I first bought it....that VW didn't offer me. It really completes the car IMO. Overall K04 was a perfect choice, and if I could go back I wouldn't do it any other way.
    Reliability:
    When the K04 was first released there have been some issues, it seems like those issues have been solved long ago as last time I heard about K04 failing was 1999. These units run as reliably as stock K03. I had my K04 for 50k miles on my old totaled Passat and I transferred it to new (used) one I bought about a year ago. So far I put another 15k miles on it(65k miles in total) and there is no signs of letting up. Engine and turbo is something that you probably don't have to worry about with these cars, however things around those 2 is a different story.
    At 92k miles (my old Passat) my axles gave up. Thank god VW took care of it under warranty . I was lucky enough not to have 1 control arm go bad....for 130k miles which is great, but many are not as lucky even with stock set ups. When everything is fine, suspension is simply superb.....when it doesn't it can be expensive to fix. Personally I have no clue how my control arms survived 6 years, my driving and horrible Northeast roads....blows my mind.
    Another failure which is very common on our cars are tie rods......on both Passats I had to replace them at about 85k mile mark. This time around I went with heavy duty ones.
    Other then that I had another 2 common issues after putting K04 on the car which might not be related to the turbo swap at all (not sure). Cat Converter flange broke at about 90k (again common on our cars) and the infamous ICM......ok fine throw in a wheel bearing in there too )again can't blame that on the turbo. Other then that it has been excellent and well beyond what I expected as far as reliability.
    Clutch is another area of concern, especially at high mileage. My clutch was only slipping on very hot days (90-100 degrees) and only when I drove it really hard, about 5-10 after couple of WOT runs it would slip. Keep in mind we are talking stock clutch at 130k miles, so in reality not bad at all. My currant Passat has 85k (bought it at 70k) and clutch is fine. It's all about how you treat the car.
    I have no turbo timer and past 3 years and 45k miles on K04 I only cooled it off on really hot days.....to be honest I don't remember last time I cooled it off. But basically I take it easy on it for a good mile before I park it at home. When I drive hard and have to go home I simply pop the hood and see if the turbo is glowing, if it is then I let it run for a min or 2. Again I haven't done it much....its fine.
    If you plan on doing burn outs.....peel outs.......and abuse this car, Passat is NOT for you and you will probably post every week about control arm failures, engine mounts gone bad....wheel bearings amongst other things. The chances are that Passat will treat you good, as long as you treat it good....and of course in some none of that matters.
    Again I had 2 Passats with 200k miles on them in total and Passat is a reliable car overall.
    Gas consumption/mileage:
    Overall I can't say my MPG went up or went down. It all depends on how heavy my foot is. If I drive like a grandma and take it out of gear on hills etc, sure I can do 35-40mpg. Just knowing that you have that option is great.
    HOWEVER when I drive hard well you waste as much gas as your average low 14s car...if not worst.
    But in general I really haven't notice any MPG changes since the upgrade, on average I get 24-26mpg the way I drive. My car gets floored at least once every time I drive, but I can't say I drive it like that much. I do not drive it hard for extensive amount of time so your mileage at the race track will probably more like 13-18mpg.
    Parts/Cost/Pricing/availability:
    There is 2 ways of purchasing, as a kit or separate. It really doesn't make a difference but you can save some money if you get it separately.
    TURBO - when I was shopping around for K04 no one had it. It took about 2-3 months to finally get it and I had to pay top dollar ($1700 as a kit) Price range from $800-1300 depending on where you purchase. I have seen lot of companies selling it and seems like K04 is common this day and age and you should be able to find it for around $800.
    SOFTWARE - there is # of companies that make K04 Chip for B5s cars.
    GIAC, WETT, Upsolute are amongst the few. If you buy the kit separately I suggest to research software first! The cost of the chip is anywhere from $400-600. I have GIAC and it costs $600.
    FPR - around $50-60 bucks
    Diverter Valve - adding an upgraded DV is a good idea too, stock DVs are prone to fail. TT DV might do the trick, I went the safe route and just got the Bailey DV. Pick and choose I would highly recommend.
    HARDWARE - make sure you have all new bolts/gaskets/washers etc. This will cost you good $20-40 but its an absolute must. I would also recommend going to VW parts dept and getting one extra hex bracket bolt, they don't come in a kit and they are VERY easy to strip.
    Here are some part #s
    K04 Turbo Upgrade, (AWE) = incl. in AWE Tuning Kit
    SEALING WASHER N 013 814 9 turbo<->coolant supply(AWE) 2
    SEALING WASHER N 013 814 9 turbo<->coolant return(AWE) 1
    SEALING WASHER N 013 812 8 turbo<->oil supply(AWE) 1
    GASKET 06A 253 039 E turbo<->exhaust manifold(AWE) 1
    GASKET 058 145 757 B turbo<->oil return line(AWE) 1
    GASKET 058 145 757 A oil return line<->pan(AWE) 1
    STUD N 044 520 3 turbo<->cat(AWE) 3
    GASKET 8D0 253 115 turbo<->cat(AWE) 1
    NUT N 903 690 01 turbo<->cat 3
    SCREW N 014 702 10 turbo<->oil return line 2
    SCREW N 010 217 10 oil return line<->pan 2
    SCREW 058 145 540 turbo<->exhaust manifold 3
    WASHER 058 145 791 turbo<->exhaust manifold 3
    BOLT N 103 036 01 turbo<->support bracket 1
    OIL - always ALWAYS use synthetic!!! Regardless if you buy a K04 or not, it's a must for 1.8T.
    COOLANT - you will need some pink stuff, make sure you have it before installation etc.
    NOTE: Some tuners will tell you that you will absolutely need an exhaust, its not true. Exhaust/DP would be good to have but its not a must but it is a good idea to do so, personally I went with Techtonics Downpipe and Stainless steal exhaust....and like it very much. Also adding an upgraded DV is a good idea too, stock DVs are prone to fail. TT DV might do the trick, I went the safe route and just got the Bailey DV. Pick and choose.
    Installation:
    This was a pretty big deal to me, if I wasn't able to install the kit myself, I couldn't afford to buy it in the first place. So basically I had to do it.
    I gathered up as much info as possible, picked a nice Sat to work on it and got my father to help me (you do need a 2nd person here and there).
    So far I did the installation twice and 1st was actually much smoother then second (broke exhaust mani bolt and stripped Allen Bracket bolt<<<<<drilled it out). But overall installing a turbo is not very hard, you just need time, right tools, patience and have all the info you need to install it.
    Keep in mind that before I bought my Passat I didn't even know how to change oil, since (thanks to Passat community) I've done anything from brakes to changing a turbo and saved over 7-8k on labor. I'm not expert or master mechanic I simply learned as I go.
    Thanks to HermanH you also have a great write up to work with.
    http://home.comcast.net/%7Ehhong4/k04install.htm
    Here are some of the things you definitely want to look out for:
    First basics
    -always use jack stands!!!
    -when loosening bolts, give it one fast/hard pull. Don't try to pull on the wrench and keep pulling on it....that's how you break the bolts. One good/hard twist will work best (something that most mechanics go by)
    -Make sure you use a torque wrench. First time around I didn't and I over tightened the washers. Ended up with a little coolant leak. Amazingly enough the leak sealed itself overtime and I didn't have to take off the turbo to fix it. You don't want to deal with any of that and it's a great piece of mind.
    -watch out for that allen hex bracket bolt. Make sure you are using correct size before you give it a good pull. As per Herman's write up a pipe will help you as it is usually very tight. But again be careful, apply the pressure in the right direction, extension pipe can cause stripping the bolt also. If you strip it, you will have to wip out a drill, get under the car and drill the bolt out. PS it wasn't as hard as I thought it would be.
    -double-check everything, rather then go back and take everything apart for the 2nd time, make sure everything is back the way it should be the 1st time. Very important.
    - As per Hermans write up, make sure the hose clamp that goes on the Turbo outlet (towards the intercooler) has its head on the bottom and the head is facing Air box side. If you put the clamp head on top or side of the hose for easy access it will NOT stay on and eventually will slip off. Basically the turbo housing is much bigger up top as the snail gets bigger and it doesn't allow the clamp to go as far in as it would if you put the clam head on the bottom and access it with the screwdriver from the bottom/side. I tried to clamp it "easy way, from the top" 3 times and it would not stay on.....always slipped off and ended up taking things apart few times.
    -Again as per Hermans write up, put some oil in the turbo before you hook up the last oil line. You don't want to start it without oil....even though it probably doesn't make a difference, again its something that could potencially cause trouble and most people that did the install recommend. I did it.....again piece of mind.
    -and last if shit goes downhill, don't ever give up. You have to keep your head up and have the confidence. I've worked on cars a LOT over last 5 years and ran into some crazy shit......yet everytime I kept a good attitude and always ended up finishing the job. Of course there were times when I had to get my anger out....and needed help from friends.....but again in the end it all works out just fine.
    OR
    you can take it to your mechanic and have them install it. I'm not exactly sure about the cost but I'm guessing it will be around 500-700 bucks. Just keep in mind unless your mechanic works for VW or on audi/vw all day he probably never changed the turbo on our cars, the chances of him doing the research and finding out what to look out for etc is very slim as most just simply get to work. Pick and choose wisely, my personal experiance with mechanics in my area hasn't been good, but I do know few very good mechanics.
    Once everything is complete simply turn the key to ON position and let it sit and let the ECU remap itself. Start it after about 1-2 min and let it run for a bit. Let all the oil/coolant burn off......you will notice some smoke. While at it, get all the air out of the coolant system and top it off. Also a good idea to have a boost gauge at this point!!!
    People say to take it easy for the first 500miles....I gave it about.....hmm......10-15 min of driving before I simply had to floor it, when I did it was all smiled from there.
    Overall impressions
    Love it! love it! love it! It is the only way to describe it. It made my car complete and it is by far the best performance mod I have ever done. Again if I could go back I wouldn't do it any other way. Not too much....not too little while still maintaining factory reliability and mileage.
    Good luck and thanks for reading.
    JACOB
    Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
    PassatWorld Staff
    Jun 2002
    Albuquerque, 1.8T A
    12,267
    Great Writeup!
    Two things:
    Quote Originally Posted by passaturbonium
    ...We still really haven't gotten to the bottom of the whole K03 Sport thing with B5.5...
    Yes we have, at least two years ago. Info Forum reveals all, to those who can read and comprehend: K03 Sport
    ...(you do need a 2nd person here and there)
    Actually, you don't - there is a spot in Herman's writeup where he points out the need for a second person. I got to that point, and at first I agreed - it's when you remove/install the turbo, the bottom oil drain piping is incredibly hard to get through it's "passageway." But if you take off the front snub passenger side mount - that bar from the back of the oil pan to the snub mount frame, and it's only two bolts - it's cake to do it with one person.
    Feb 2001
    ocala fl
    1,604
    awesome write up thanks for sharing
  5. Remove Advertisements
  6. #4
    Aug 2005
    Miami, Fl
    199
    nice writeup!
  7. #5
    Feb 2006
    London, United Kingdom
    57
    One thing is missing IMO . You could add some words about different types of k04's, for those guys who are new into the subject.
  8. #6
    PassatWorld Staff
    Jun 2002
    Albuquerque, 1.8T A
    12,267
    But only one type of K04 fits our cars...
  9. #7
    5th Gear
    Mar 2003
    Louisville, KY
    6,172
    Great Writeup!
    x2
    I'd say that the K03 "sport" --> K04-15 info for B5.5's is still "vague" at best, mostly due to still-undocumented software/tuning issues... but that's a topic for another thread.
  10. #8
    Nov 2002
    Planet Earth
    40
    17,568
    Thx guys
    Quote Originally Posted by Rusty
    Great Writeup!
    Two things:
    Even though One8T gave us a lot of answers and it seems like K03 sport on B5s is similar to K03........then NUICENCE and Sparky kind of proved us all wrong.
    Thats why I kind of said its up in the air.
    Also no before after dyno plots make it even harder.
    As far as the passage way......it is duable for sure, heck you can even attach a rope before you pull it out, just makes it much more easier with another person.
    Very good points though
  11. #9
    Feb 2005
    the Netherlands
    2,335
    Great addition to HermanH's write-up
  12. #10
    Nov 2002
    Planet Earth
    40
    17,568
    Agreed, even though there is MANY K04s out there once you get into anything outside of K04-015 you are talking different "unavialable" or not mainstream software and totally different Cat set ups (custom).
    I could add something in there about that though....any suggestions?
  13. #11
    Feb 2006
    57
    I couldn't agree more.
    But there are many of k04's on the market, some of the guys selling k04-23 as a direct bolt-on i.e.
  14. #12
    Jul 2004
    Vancouver, BC
    33
    1,072
    can this go in the info forum?
  15. #13
    6th Gear
    Aug 1999
    Minneapolis , Minnes
    8,200
    Quote Originally Posted by Dirty Dan
    Yes.
  16. #14
    Dec 2004
    Pennsylvania
    32
    471
    Great write up!
  17. #15
    4th Gear
    Aug 2003
    Fairfield County, CT
    3,482
    heh, i was thinking of writing a similar guide
    some things to add...a compiled list of software and fueling setups per engine type would be nice.
    anyway here's a list of hardware (from my website):
    and if you are removing the exhaust manifold for porting:
    Install Extrude Honed Exhaust Manifold
    SELF LOCKING NUT N 900 850 01 or use N 902 002 01 TT ver. 13
    WASHER N 903 572 01 8,4x15x4 13
    GASKET 058 253 039 G - 1
  18. #16
    4th Gear
    Jul 2005
    Manchester, NH
    2,956
    Couple of things
    1. For clarity I would suggest refering to it as BHP rather than just HP. You know somebody is going to get all jazzed about having 230hp at the front wheels and then be hugely disappointed when they dyno at 195-200. Too often people confuse BHP and WHP - particularly those that don't have any clue.
    2. The K04-15 turbo is pretty commonly found for about $700 these days - Kinetic Motorsport being one retailer in that range.
    3. I would suggest that anyone doing the upgrade also install new oil lines for the turbo at the same time - they aren't included in many of the kits but its a good idea to do it if the lines are older (more than 2-3 years).
    4. You might want to mention that most of the software companies will upgrade you to K04 software if you've already chipped the K03 for a fraction of the price of buying software for the first time.
    And there is a definitive answer regarding the K03 sport. It comes directly from Borg Warner in that they have said (and the copy of the email is on the internet in a lot of places) that they have never made a turbo referred to as a K03 Sport or K03s. They did produce a turbo for the transverse engines that had dual impellers on a K03 body, but this was never produced for the longitudinal engine. Anyone with a K03 "sport" turbo actually has either just a later model K03 and thinks its a more powerful turbo because their car had 20 more BHP stock, or they have an aftermarket turbo that was built by someone other than Borg Warner from BW parts.
    Mike
  19. #17
    Feb 2006
    57
    Kinetic Motorsport is more in $800 then $700 price range - atleast that's what their website says. I am just about to order one and looking for the cheapest distrubutor.
  20. #18
    Nov 2002
    Planet Earth
    40
    17,568
    Quote Originally Posted by modifiedA4
    Thanks!!! Added
    I will have to modify the rest a little later, keep em coming though more the better.
  21. #19
    Founder of the STFA
    Feb 2003
    Ohio
    8,667
    Need them to use the Rusty email dyno!
  22. #20
    4th Gear
    Jul 2005
    Manchester, NH
    2,956
    Quote Originally Posted by binary
    Register on www.b5one.com and when you order from Kinetic, speak to Clay and let him know you're from B5ONE. He'll verify it, and you'll get the K04-15 for $705.
  23. #21
    4th Gear
    Jun 2004
    Sacramento, CA
    39
    4,263
    great write up! bookmarked for future reference!
    to you!
  24. #22
    Feb 2006
    57
    Quote Originally Posted by [email protected]
    Thank you very much
  25. #23
    May 2000
    Finger Lake Region
    74
    Excellent write up, and great to hear you're getting lots of miles and smiles out of it.
  26. #24
    needs more cowbell
    Apr 2003
    Maryland
    41
    5,946
    FWIW i paid about 5-6 hours labor for the turbo install. calculate that at your local rate. as jacob said, it's about 350-500 bucks said and done. (that's a LOT of tools/jack stands that you can use in the future-i didn't have time with new baby)
  27. #25
    4th Gear
    Aug 2003
    3,482
    b5one seems like a pretty established site, the forum is packed...whats the deal? is it like the audiworld/audizine situation?
  28. #26
    Apr 2001
    Wallingford, CT USA
    196
    Great Write Up.... Thanks for takin' the time & sharin'!
  29. #27
    4th Gear
    Jul 2005
    Manchester, NH
    2,956
    Nah, its nothing like that. Its just a great site for B5 and B5.5 info and is a good compliment to PW.
  30. #28
    4th Gear
    Aug 2001
    Southern, AL
    57
    4,817
    Slapping on a K04 and not replacing the restrictive stock exhaust system (from cat back) is leaving at least 15HP on the table.
    Thermal issues after installing a K04 are less prevalent (compared to a chipped K03). The K04 will give you lower intake temps while pushing more air (improved compressor wheel -vs- stock K03)
    Edit: For reliability, running the fuel pressure at 4 bar or below is preferred. There is less precise control of fuel delivery when running the injector at 5 bar -vs- 4 bar or less. Not to mention, the rest of your fuel system is also at ~73 psi with the 5 bar FPR. Chose larger injectors and an adjustable FPR along with appropriate software for safety and long-term reliability.
    Good write-up.
  31. #29
    PassatWorld Staff
    Jun 2002
    Albuquerque, 1.8T A
    12,267
    ...Even though One8T gave us a lot of answers and it seems like K03 sport on B5s is similar to K03........then NUICENCE and Sparky kind of proved us all wrong...
    When and How did this happen? I do not recall any such event(s). They're def tops in the K03 HP department (I know I woulda been right there with them if my K03 wasn't worn out), but it has nothing to do with the turbo, and everything to do with all the extra mods and tuning they've done. Mad props.
  32. #30
    5th Gear
    Nov 2005
    South Florida - K03 Sl0w Spd
    32
    5,514
    dAm man i want to do this mod so bad but it cost too much becuase i wont have the guts to install this myself
  33. Remove Advertisements
