Dash Board Temp Warning Nottice
Results 1 to 17 of 17
Like Tree1Likes
  • 1 Post By PZ
Thread: Dash Board Temp Warning Nottice
    Dec 2011
    Glens Falls NY USA
    94
    Exclamation Dash Board Temp Warning Nottice
    On my 1.8T recently had "O" ring gasket leak on driver's side of coolant flange at rear of engine. Was on interstate when leak started. Stopped three times to refill system before reaching my destination. Each time engine overheated (temp gauge went to max) before I got refill.
    Thinking plastic Coolant Flange was cracked, I replaced it (nasty job) including its gaskets and refilled system venting the air out at the heater connection.
    Engine coolant system now works fine, temperature gauge sits in mid-range as it normally did, heater and AC work fine. BUT the dash board exhibits the flashing temperature light and says "STOP" and "see manual". Made sure I re-connected the wires to the two temp sensors and gauge shows normal. Would not be comfortable driving with these warning flashing.
    I don't have a code reader device but is this a case of just erasing the overheating problem code from the car's computer ?
    Jun 2015
    Memphis, Tennessee
    57
    318
    Quote Originally Posted by northcountryguy1 View Post
    It may not be as easy as that as a faulty coolant temperature sensor may be triggering the warning. At least replacing the sensor is easier than replacing the flange.
    Feb 2019
    Vermont
    124
    the ECTS is a ten dollar part on amazon an quick swap out.
    https://www.amazon.com/Allroad-Volks...dp/B00OYI9XW0/
    Though I doubt this is actually your problem.
    My guess is that either the coolant reservoir sensor is shot or not connected.
  5. Remove Advertisements
  6. #4
    Dec 2011
    Glens Falls NY USA
    94
    Thanks guys. The temp sensor was working ok before the overheating problem, and the dash gauge now reads at the same mid-normal level that it showed before the overheating, so I figured that sensor was okay. But who knows, it could have been "damaged" in some way that triggers the dash warning light. First I'll check the connection under the reservoir to be sure its connected.
    So, since no one so far has expressed that a computer code could have been "set" that would cause the dash warning light, I'll assume that's not an issue.
  7. #5
    Feb 2019
    Vermont
    124
    Google around and you can find ways to get the code without a code reader...or you could go to any auto parts shop and they will read it for you for free usually...or buy a cheapo ten dollar elm327 clone and it will get you by.
    the ECTS actually has two sensors in it (I recently learned its not just two outputs, but actually two sensors)...one feeds the dash, and one feeds the ECM....your dash feed may be fine but your feed to the ECM may be shot and thus there could be issues caused by the computer thinking your coolant is much hotter or colder than it is....
    and about the coolant reservoir sensor...when I had forgotten to plug mine back in after burping the system, the car lost its shit as soon as i turned it back on with the STOP, SEE MANUAL and temp light.
  8. #6
    2nd Gear
    Jun 2012
    Colorado
    842
    Hopefully it's just the wires under the coolant tank are not connected. The other options aren't good.
  9. #7
    Aug 2011
    Westerville, Ohio
    1,037
    Take a look at this recent thread. I talk a bit about the coolant temperature sensor in post #5.
    https://www.passatworld.com/forums/v...-96kw-avf.html
    You can, indeed, have a valid reading on the temperature gauge and a faulty reading to the ECM, or visa versa.
  10. #8
    Dec 2011
    Glens Falls NY USA
    94
    Well you all .... your "easy" fix, the wire harness connection under the reservoir, was the problem .... thank goodness. I forgot to reattach it.
    Now my new problem: the coolant pipe connection on the driver's side of the plastic coolant flange keeps dripping. The "o" ring doesn't seem to seal the connection. Took it apart from top-side and carefully reconnected it, to no avail. Bad design: The two bolts holding the connection are not opposite each other thus a "lop-sided connection. Will try adding some Permatex sealant next.
  11. #9
    Overdrive
    Feb 2007
    Lehigh County, Pa.
    64
    12,058
    Aftermarket flange? If so, not entirely unexpected - people haven't had good luck with those. I'm dubious sealant will help much.
  12. #10
    PZ
    PZ is offline
    Redline
    May 2002
    Grapevine TX. 01 4M
    56
    25,837
    Sealant will not help, I've been through that with aftermarket flanges. If it's an OEM flange, buy a new seal, loosen the metal coolant pipe and then install the new seal. Tighten the metal coolant pipe bolts last.
  13. #11
    Feb 2019
    Vermont
    124
    @PZ
    Can you point out where this is exactly?
    I have a yet-to-found coolant leak and perhaps this is where it is.
  14. #12
    PZ
    PZ is offline
    Redline
    May 2002
    Grapevine TX. 01 4M
    56
    25,837
    This is the writeup with pics. The flange is behind the head, under the PCV hoses and combi valve.
    https://www.passatworld.com/forums/b...placement.html
  15. #13
    Feb 2019
    Vermont
    124
    Copy, I think I know where to look for it now in my 2.8.
    I as soon as I get my truck up and running I will have time to work on the VW again.
    The truck was supposed to happen yesterday but life got in the way.
    Maybe wednesday night.
  16. #14
    PZ
    PZ is offline
    Redline
    May 2002
    Grapevine TX. 01 4M
    56
    25,837
    The V6 has metal pipes but the O-rings can go bad. I've had both of my son's V6 cars in this year with leaking seals at the temp sensor and the coolant tank. There are several pipes under the intake that can leak, I've replaced those seals on my younger son's car several years ago. I have a writeup in the Info section but no pics. Here is a writeup with pics for the CTS:
    V6 Coolant Temperature Sensor Replacement Writeup - PassatB5
  17. #15
    Feb 2019
    Vermont
    124
    yeah CTS was one of the first things done on the adopted b5.5.
    I have a not so random misfire on cyl 2 happening after it rains. disappears after a couple minutes. also its like two misfires over that few minutes, but still.
    It only happens after it rains.....need to chase that down...again once the truck is fully up and running.
  18. #16
    PZ
    PZ is offline
    Redline
    May 2002
    Grapevine TX. 01 4M
    56
    25,837
    The misfire is probably the plug wire.
    FrescoGreen01.5 likes this.
  19. #17
    Feb 2019
    Vermont
    124
    That is going to be my first go to...considering the last time i was at the scrap yard i grabbed an extra set of all the plug wires....Maybe do that tomorrow night.
  20. Remove Advertisements
