Brake reservoir leaking?
Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By ylwagon
Thread: Brake reservoir leaking?
    Apr 2019
    Tampa, FL
    14
    While doing some maintenance I notice the brake reservoir seems to be seeping out of this scrunched/nipple/connection.
    There is a bit of fluid underneath this, and when I place my finger on the side/opening, a bit comes off/out.
    Pictures attached.
    Is this normal design? (having the connection melted/crimped shut?)
    Can I place a stop-tube of some sort on this? Or should the reservoir be replaced?
    04' TDI
    Attached Images Attached Images
    5th Gear
    Sep 2002
    Fallbrook CA USA
    5,129
    That tube is used to supply brake fluid to the clutch master cylinder, when a manual trans is installed. The crimped end should not leak though. A replacement reservoir is not a bad idea, and you'll be able to see the fluid level much easier.
    AndreasPassat likes this.
    4th Gear
    Jul 2006
    Phoenix, AZ
    52
    3,997
    Ironically enough mine is leaking too.
    Except mine is broken from the intense heat and the reservoir cracked open along the molded joint that makes up the top and bottom halves.
  5. Remove Advertisements
    Similar Threads
    1. Brake fluid leaking from cap on reservoir
      By PGevanthor in forum B5 Garage
      Last Post: 11-11-2015, 03:16 PM
    2. Brake hose crack, brake reservoir crack. Serious?
      By mikefl in forum Volkswagen Passat B5 Discussion
      Last Post: 06-30-2013, 11:02 AM
    3. Brake fluid leaking from reservoir cap
      By 2002GLXV6 in forum B5 Garage
      Last Post: 02-10-2013, 05:28 PM
    4. 2002 Passat leaking Coolant from reservoir
      Last Post: 03-02-2011, 02:19 PM
    5. 2002 Passat leaking coolant from reservoir
      By cableguynoe in forum Volkswagen Passat B5 Discussion
      Last Post: 02-20-2011, 12:08 PM
